I found this wouldn't stop spin
  • Thread starter Thread starter sleepsleep
    Spin
The discussion reveals that lowering and raising a spinning object by 2 or 3 mm increases its spin rather than stopping it. An illustrated diagram is provided to support the findings. The PNG file format is mentioned, highlighting its compatibility with various web browsers. The conversation emphasizes the unexpected results of the test conducted. Overall, the experiment challenges assumptions about stopping spin dynamics.
sleepsleep
i tried the following test, and found it wouldn't stop spin and in fact would spin more faster if u low it 2 or 3 mm and raise it up 2 or 3 mm during it spins.
the "illustrated diagram" (the best i could draw using paint shop pro) :p
http://www.boinc.ch/~sleepsleep/energy.png
What kind of file is a PNG extension?
png is portable network graphics ( http://en.wikipedia.org/wiki/PNG ) , it could be viewed with IE browser, or firefox or opera or etc
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
