I need electrical comparison help, anybody?
The discussion revolves around comparing technical specifications of dental magneostrictive ultrasonic scalers. Participants seek to understand the differences and similarities between three specific models, focusing on their electrical and operational characteristics.
  • The first unit has a supply voltage of 115-230 V, a maximum power consumption of 30 VA, and a minimum vibration frequency of 28-36 kHz.
  • The second unit operates at 100V-240V with an output power range of 3W to 20W and a frequency of 28 kHz ± 3 kHz.
  • The third unit also operates at 100V-240V and has similar output power and frequency specifications as the second unit, but includes additional details about vibration excursion and force.
  • Some participants express confusion about whether the first unit functions as both an autoclave and an ultrasonic cleaner, with differing opinions on its effectiveness for sterilization.
  • There is a discussion about the significance of output pressure settings, with some participants suggesting that lower pressure settings might be beneficial in certain situations.
  • Cost comparisons are made, with the first unit being significantly more expensive than the third, leading to considerations about functionality versus price.
  • Concerns are raised about the quality of products from different manufacturers, particularly those from China, and whether they meet the necessary standards.
Participants do not reach a consensus on which unit is definitively better, as opinions vary regarding the importance of different specifications and the implications of price versus functionality.
Some specifications are not uniformly available across all units, making direct comparisons challenging. Additionally, there are uncertainties regarding the sterilization capabilities of the first unit and the implications of the various pressure settings.
This discussion may be useful for dental professionals or individuals considering the purchase of ultrasonic scalers, particularly those interested in the technical specifications and comparative analysis of different models.
Suzanne
I want to purchase a dental magneostrictive ultrasonic scaler. I need help with comparisons on technical specifications.
Can anyone help me determine what is the best unit as far as output goes, if I give you the specifications?
(Obviously I do not know electrical stuff - Just teeth)
Welcome to PF :smile:
Perhaps you could go ahead and post the specs, and maybe somebody can answer your questions. (It's hard to know if we can help without having seen the specs.)
I want to compare three products.
Can you tell me which, if any is better than another.
FIRST:
Supply voltage: . . . . . . . . . . . . . 115-230 V~ 50 / 60 Hz
Equipment classification: . . . .. . . Class II - BF type
Operating conditions: . . . . . . . . . Intermittent duty 10 min. / 5 min.
Max. power consumption: . . . . .. . 30 VA
Min. vibration frequency: . . . . . . 28-36 kHz
Water pressure: . . . . . . . . . . . . . 1 to 5 bar (14 to 72 psi)
Water filter: . . . . . . . . . . . . .. . . 60 µm
Operating temperature
+10 to +40°C at 95% RH max. without condensation.
Storage temperature
-20 to +70°C at 95% RH max without condensation.
Sterilization of handpiece and accessories (wrenches, storage kits, etc.) in an autoclave according to ISO 11134 Standard: Temperature: 134°C (273°F);
Pressure: 2 Bars (29 P.S.I.); Sterilization time: 18 minutes.
2nd
Supply voltage:100V -240V 50/60Hz 1.2 (max)
main unit input: 30VDC 1.3 A
Output power: 3W - 20W
Frequency: 28kHz +- 3kHZ
water presure: 0.01 MPa -0.5 MPa
sterilizable pressure to 0.22 MPa
3rd
Power input: 100V to 240 V~ 50Hz/60Hz 1.2A (max)
Main Unit input: 30VDC 1.3A
Output primary tip vibration excursion: (less than?The sign was the sideways V pointed to the left with a line under it) 100 µm
Tip vibration Frequency: 28kHz +- 3kHz
Output half-excusrion force: Less than 2N
Output power: 3W to 20W
Main unit furse: 250VT to 1.6 AL
Adapter fuse: 250 VT 2.0 AL
Water Pressure: 0.1bar to 5 bar (0.01MPa to 0.5MPa)
FIRST:
Storage temperature
2nd
3rd
I'm confused; is the first one an autoclave as well as an ultrasonic cleaner? Your general purpose ultrasonic cleaner will agitate and work loose the crud in all the nooks, crannies and knurling of your tools. I'm not sure how effective this is in sterilizing your tools, but I think you're supposed to autoclave after cleaning.
As for the actual ultrasonic output, II and III look to have the same; I may or may not, since they only give the power consumption (which, as I say, may or may not include the autoclaving function--the specs read a little ambiguously)
The OP said scaler, not cleaner. It seems to be for cleaning teeth, not instruments. (I know electronics, not teeth).
I wouldn't worry about the input power specs. All units seem to use 30 to 40 Watts, less than a typical light bulb i.e. not very much.
They all run at about 28,000 vibrations per second, though Unit 1 might be as high as 36,000.
Comparing output pressures in like units, using 1 bar = 0.1 MPa:
Unit 1: 0.1 to 0.5 MPa
Unit 2: 0.01 to 0.5 MPa
Unit 3: 0.01 to 0.5 MPa
So, Units 2 & 3 are capable of a lower pressure setting (1/10th) compared to Unit 1. All units have the same maximum pressure of 0.5 MPa or 5 bars. That's about 5 times atmospheric pressure.
Is a low, "softer" pressure setting useful in some situations? That might be a reason for choosing #2 or #3.
Several of the specs are listed for one unit and not the others, so we can't compare things like "Output half-excusrion force" for example.
And of course, cost would be another consideration.
Hah! I should read more completely. Scaling ...
http://en.wikipedia.org/wiki/Tooth_scaling
I suppose that also explains why they list a sterilization temperature and time under device I.
Thank you both so much for your replies.
Spec 1 is probably 4 times the cost of #3.
I just wanted to see if the units were comparable for what they can do. #1 is about $2500 and would be imported from France.
#3 can be purchased for about $600 from China. I don't care where it comes from as long as it can do the same thing as #1.
So if #3 can function the same as #1, then that's my choice.
Thanks again : )
You're welcome.
For what it's worth, I'm rather leery of Chinese products. The quality control can leave a lot to be desired with some of the companies over there.
How much is #2? If it's within a couple hundred $ of #3, it might be worth it.
Here is the website for # 2
http://cgi.ebay.com/NEW-ULTRASONIC-PIEZO-SCALER-WITH-LIQUID-DOSING-DTE-D7_W0QQitemZ230325739237QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item230325739237&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
and #3
http://cgi.ebay.com/Satelec-Compatible-Dental-Ultrasonic-Piezo-Scaler-D5_W0QQitemZ220359921570QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item220359921570&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1308%7C301%3A1%7C293%3A1%7C294%3A50
These scalers are listed on Ebay. I don't need the water resivoir in # 2, but for some reason it looks like it does more than#3.
Tell me what you think.
Thanks,
Suzanne
P.S.
Both #2 and #3 are made in China.
They both have a year warrenty, which is the same warrenty as the one made in France.
Suzanne said:
P.S.
Ah, in that case it probably doesn't matter.
I am terrible (as you can tell) about making decisions and you have helped me.
At least I now "know" that the scalers from China funcion about the same as the one from France, and that is what I was looking for.
Thnak you again for your help.
Suzanne
honestly, I'm a bit skeptical of being able to judge the products based on the specs.
Very true. Especially if the specs reported aren't exactly, how would you say, "typical" of the average unit. To the OP, assuming you're a hygienist or a dentist, are there trade magazines or colleagues that have any of the above machines, or, at least, familiarity with those brands? Well, you could always be the first of your cohort/class/circle.
I asked on a "dental forum" if anyone had used the Chinese brand and only got one reply. They said it was a good unit.
Most dental scalers are made in the US. I do not know what the typical "specs" of scalers are and only inquired about the similarity between the 3 listed above because the one from France is considered the "Ferarri" of scalers. So I wanted to find comparisons on that one specific brand.
This is a really fun and informative forum.
Thank you all for your interest and help. : )
PS: Where is the spell check?
There is no spell check; use Firefox to get one built-in (great for Webmail or these forums, BTW--yes, yes, I'm sure there's an IE plug-in, but Firefox is all-around better):
http://www.mozilla.com/en-US/firefox/
EDIT: Said respondent wasn't a new poster with only the single post, were they? Sometimes you get shills going around to spread some word-of-mouth, or a con, and that's usually the best indicator. On the other hand, your question may have motivated a first-time poster, long-time lurker to say something. Just FYI.
