Triangle Math Help: Find a, b When c=4 & θ=20°
  • Thread starter Thread starter angelcase
    Triangle
The discussion revolves around solving a right triangle problem where the hypotenuse (c) is 4 and the angle (θ) is 20°. The user initially calculated the lengths of sides a and b using sine and cosine but received incorrect results. A suggestion was made to correctly place the angle between sides b and c, leading to the equations sin(20°) = a/4 and cos(20°) = b/4. The conversation also touches on using trigonometric identities to find tangent values without inverse functions. Overall, the focus is on clarifying the correct application of trigonometric principles to solve for the triangle's sides.
angelcase
I need help...
I am taking physics for the first time and I am taking it online which probably isn't the smartest way to go...but to make matters worse I am also currently enrolled in the calculus class that is a prerequisite for the course at the same time so my math skills are not really up to par...If anyone can help me get through this semester with a better understanding of the course material it would be greatly appreciated...Thanks
Let the three sides of a right triangle be designated a, b, and c where c is the hypoteneuse. If c = 4, and if the angle between c and b is θ = 20°, find the lengths of the other two sides.
Mathematics news on Phys.org
Start by drawing a diagram of the triangle and put in the angle θ.
You should know that
sinθ = opposite/hypotenuse and cosθ=adjacent/hypotenuse.
First off, thank you for responding so quickly...
I drew a diagram and labeled the sides, then I used sin and cos to find the sides a and b...I got sin (20)= b/4 and cos (20)= a/4...found b= 1.3681 and a= 3.75878...the computer marked my answers wrong...
Given sinθ = 0.6, calculate tanθ without using the inverse sine function, but instead by using one or more trigonometric identities. You will find two possible values.
I found one of the values using sin^2 (theta) + cos^2 (theta) = 1
I tried using cos (90 + theta)= sin theta to find the second one, but couldn't remember if you were able to distribute the cos...since addition is communitive or whatever that property is called...and get cos 90 + cos theta= sin theta
I think you put the angle in the wrong place. You need to put the angle between the sides b and c.
Which would give you sin(20)=a/4.
Ok well you know that sinθ is positive in quadrants 1 and 2.
So in quadrant 1, draw a triangle at the angle θ.
sinθ = 0.6 = 3/5 = opposite/hypotenuse
Meaning that in your triangle, wrt θ, 3 is opposite and 5 is the hypotenuse.
If you are unsure as to what I meant by quadrants, read http://myhandbook.info/form_trigono0.html" , the section titled "Trigonometric Functions in Four Quadrants"
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
