I need some explanation on this
  • Thread starter Thread starter flyingpig
    Explanation
The discussion revolves around understanding the resistance calculation in a problem involving a rectangle formed by nichrome wire. The key point is that the total resistance is calculated by adding the lengths of the three sides of the rectangle, which includes one height (L) and two widths (2x), while the rod itself has negligible resistance. Participants clarify that the rod's length does not contribute to the resistance since it is multiplied by zero. There is some confusion about the dimensions, but it is established that the relevant length for resistance is L plus the two widths. The explanation ultimately helps clarify the reasoning behind the resistance formula used.
flyingpig
[PLAIN]http://img23.imageshack.us/img23/949/unledto.png
Go to problem b)
[PLAIN]http://img850.imageshack.us/img850/5388/unledzb.png
Now my question is why L + 2x? L is the height and x is the width, why are they adding them? I know \lambda is the resistance per unit length, but I don't understand they are adding them. It would make sense if they added the entire arclength (perimeter) of the rectangle
The problem says the rod has negligible resistance, which means that you only need to add up the lengths of the three sides of the rectangle that are formed by nichrome wire. This is one height (L) and two widths (2x).
What about the distance PQ?
The distance between P & Q is L.
OK!
Resistance is: R = λ(2x + L) + 0(L), because, as cepheid pointed out, the rod has negligible resistance.
Code:
  P--------------------
   |            x
   | L
   |            x
  Q--------------------
Just to be clear, these are the three sides of the rectangle I was referring to. (The fourth side, made by the rod, is not shown). Adding their lengths up, we get:
L + x + x = L + 2x
SammyS said:
OK!
It's okay, OnlyMe explained it to me pretty well lol.
Also, the rod isn't length L, look closely...
Maybe not, but the portion of it that conducts current and is part of the loop has length L...not that it matters since it has no resistance and hence you multiply it by 0 anyway. :rolleyes:
