I would like to create a lifepo4 battery-bag that is failproof.
  • Thread starter Thread starter Wheazel
The discussion focuses on creating a lightweight, user-friendly lithium iron phosphate (LiFePO4) battery bag that can replace traditional lead car batteries for applications like powering electric motors and jump-starting vehicles. The goal is to design a complete unit that is easy to handle and can be charged using standard methods, while also incorporating protective circuits to prevent deep discharging and misuse. The conversation acknowledges the high costs associated with this technology, estimating several hundred dollars for the necessary components. There is a clear preference for lithium batteries due to their superior energy density compared to gel batteries, despite the challenges in handling them. The user seeks advice on the technical solutions required to achieve a practical and safe design.
Wheazel
Hi
I have a wish to create a bag that is intended for carrying a lithium battery that I can use as replacement for a regular lead car battery. Main reason I want to do this is to get something that is less of a pain to move around. For example power my minnkota electric boat motor, or be used as starthelp when the cold killed my regular car battery.
Ofcourse it is no problem to just put some batteries in a bag and have the cells charged separately, but I would like a complete unit that can be handeled like a lead battery.
If I could reach anything I was hoping for, the battery should be able to handle charging from a generator in a car or boat if decided to put there. Also be protected from deepdischarging by some circuit. Allow charging with a regular lead battery charger. So basically the circuit of the batteryunit would shield the lithium battery from abuse it wouldn't handle.
What technical solutions am I looking at to accomplish something like this? Possible?
Thanks.
First, NOTHING is fail-proof.
Next, have you priced the technology? At the minimum, you're talking about hundreds of dollars.
Thanks for the input. Let me put it like this.
Failproof enough to be used by the average joe with no special knowledge about lithium battery treatment.
Yes it is several hundereds of dollars. I know how much cells are, what I don't know is the cost of a solution capable of what I am thinking. Hoping to get an idea by understanding what actually is required in terms of electronics. Sadly I am no electronics engineer myself.
Why not use a 12 V Gel battery? They come in different sizes and aren't nearly as difficult to work with as a lithium battery.
Because they still are heavy, and doesn't offer the same energy density. I want something that is light to carry. Around 10kg, and still have enough energy to be compareable to a smaller car battery.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
