How Does a Rising Bubble's Volume Change with Pressure and Temperature?
  • Thread starter Thread starter 6021023
    Gas Ideal gas
6021023
A diver observes a bubble of air rising from the bottom of a lake (where the absolute pressure is 3.50 atm to the surface (where the pressure is 1.00 atm). The temperature at the bottom is 4.0 C, and the temperature at the surface is 23.0 C}.
What is the ratio of the volume of the bubble as it reaches the surface to its volume at the bottom, V2/V1?
p1V1/T1 = p2V2/T2
V2/V1 = p1/p2 * T2/T1
V2/V1 = (3.5)/1 * 23/4
V2/V1 = 20.125
How would you solve the problem if the temperature was given to you in Fahrenheit?
I would convert to K. That gave me the correct answer. Thanks!
Also, there's a second part to this question:
"Would it be safe for the diver to hold his breath while ascending from the bottom of the lake to the surface?"
My first answer would be no, because the solution V2/V1 = 3.74 shows that the volume of air expands more than three times, but I think that the temperature inside the diver should stay the same, and so it won't expand like this. What's the answer?
Well, you could assume that the temperature doesn't change from the bottom to the top - you will still get a factor of more than three. What other difference is there between a diver and a bubble? :smile:
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
