How Do You Calculate the Probability Density p(E) for an Ideal Gas?
  • Thread starter Thread starter ehrenfest
    Gas Ideal gas
ehrenfest
The following is a probability density distribution for an ideal gas:
p(v_x,v_y,v_z) = (2 \pi \sigma ^2)^{-3/2} \exp\left({\frac{v_x^2 +v_y^2+v_z^2}{2 \sigma^2}}\right)
E = 0.5 m |\vec{v}|^2
Find p(E).
I want to just plug in what E but that gives the wrong answer and I cannot figure out why.
p(E) = (2 \pi \sigma ^2)^{-3/2} \exp\left({\frac{E}{m \sigma^2}}\right)
Why is that wrong? It makes no sense, but I just plugged in what E was! This is really bothering me.
Find p(E).
What is the correct answer? It's a probability *density* so there is also a factor dv_x dv_y dv_z that must be multiplied to get a probability. If you want the probability density in terms of the energy you wil have to relate the above factors to the infinitesimal dE
EDIT: it's a density in speed so the factor to convert is probably dv
Interesting. BTW, is it generally true that if y=y(x) and x=x(z), then y=y(x(z))? That is, you can write y as a function of z just by plugging in x as a function of z. That rule seems to fail here. But in general, when is it true?
ehrenfest said:
Interesting. BTW, is it generally true that if y=y(x) and x=x(z), then y=y(x(z))? That is, you can right y as a function of z just by plugging in x as a function of z. That rule seems to fail here. But in general, when is it true?
It is true in general, yes.
The problem here is that what you are looking for is *not* simply y(x(z))!
what you are looking for is the probability density in energy so the probability of measuring an energy between E and E+dE.. If you just plug in v in terms of energy, you are still giving the probability density in *speed*, so you are giving th eprobability of measuring the speed between v and v+dv. This is not what you are asked to find!
So, back to the original problem. p(v_x, v_y, v_z)dv_x dv_y dv_z[/tex] gives the probability of finding the particle&#039;s velocity in the box with side lengths dv_x, dv_y, dv_z with the one corner at (v_x, v_y, v_z).<br /> <br /> And I want to find p(E) such that p(E)dE[/tex] gives the probability of finding the particle&amp;#039;s energy between E and E+dE. &lt;br /&gt; &lt;br /&gt; We know that dE = 1/2m(2v_x dv_x + 2v_y dv_y+2v_z dv_z), but I still don&amp;#039;t really know how to proceed. Do express each of dv_x dv_y dv_z as a function of dE somehow?&lt;br /&gt; &lt;br /&gt; You said something about just using dv, but I am not sure what you meant. Can you elaborate?
&lt;br /&gt; &lt;br /&gt; You can&amp;#039;t directly get from the distribution in v_x, v_y an dv_z to the density in Energy since there is more information in the first than in the second (since E depends only on v^2). So you need to find the probability density in the speed first. So you integrate over all directions using dv_x dv_y dv_z = v^2 dv d\Omega. But the result of the angular integral is simply 4 \pi v^2 dv times the probability density in v_x, v_y and v_z so&lt;br /&gt; &lt;br /&gt; \rho(v) dv = 4 \pi \rho(v_x,v_y,v_z) v^2 dv&lt;br /&gt; where it is understood that in the sceon term you rewrite everything in terms of the speed v.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
