Ideal monatomic gas engine problem
  • Thread starter Thread starter ken12380
    Engine Gas
The discussion centers on calculating the total heat added during a heat cycle of an ideal monatomic gas in a cylindrical container. The gas experiences changes in pressure and volume at specific points, with known values for pressure and volume at each stage. The user initially attempted to calculate heat using both constant pressure and constant volume equations, resulting in an incorrect total. The correct approach involves determining when heat is added to the gas, specifically during pressure increases at constant volume and during expansion at constant pressure. The key takeaway is to focus solely on heat flowing into the gas for accurate calculations.
ken12380
An ideal monatomic gas is confined to a cylindrical container having a movable, yet "snuggly-fitting," lid that slides up and down to accommodate changes in pressure and volume. The diagram shown below, outlines the steps in a heat cycle starting at position A and moving through positions B, C, D and then back to A.
*ignore the axes labels*
PV diagram2
Given:
PA = PB = 12.0 atm
PC = PD = 6.0 atm
VA = VD = 5.0 m3
VB = VC = 30.0 m3
temperature of point C is 900 K
moles of gas are present 2437.3376
How much total heat is added during the cycle?
Q=nCp delta T
Q=nCv delta T
PV=nRT
I tried:
Q=Q+Q=nCp delta T+nCv delta T=2437.3376*20.78*150+2437.3376*12.47*1500
=53187581 J but this is wrong.
Why? and what is the actual answer?
You have to determine where heat is being added. It is being added(flowing into the gas) when the gas pressure increases at constant volume and when the gas expands at constant pressure. Heat flows out when it loses pressure at constant volume and when it is being compressed at constant pressure. You have to calculate only the heat flow INTO the gas.
AM
