If xy^2 = ab^2 : Does xy = ab?
  • Thread starter Thread starter Femme_physics
The discussion revolves around the equation xy² = ab² and whether it implies that xy = ab. Participants explore the implications of the original equation and the conditions under which the equality might hold.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Some participants question the assumption that xy = ab follows directly from xy² = ab², suggesting that other scenarios, such as xy = -ab, could also be valid. Others explore specific numerical examples to illustrate the point.
The discussion is active, with various interpretations being explored. Participants have offered insights into the conditions under which the original statement might hold true, particularly focusing on the implications of squaring terms and the significance of variable relationships.
There is a mention of potential confusion regarding the notation used, with some participants suggesting that the original poster may have intended to express (xy)² = (ab)² instead of xy² = ab². Additionally, the impact of zero denominators is noted as a relevant consideration in the discussion.
Femme_physics
If
xy2 = ab2
Does that mean automatically that xy = ab?
Not necessarily. It's possible that xy = -ab.
Got it :) Thanks
Let's try something.
[itex]1 \cdot 2^2 = 4 \cdot 1^2[/itex] is true isn't it?
But is: [itex]1 \cdot 2 = 4 \cdot 1[/itex] ? :confused:
Oh, I was assuming the OP meant (xy)^2 = (ab)^2. If it's how you're suggesting, then (if x y^2 = a b^2, then xy = ab) only if y=b.
@CL: I suspect that it was what the OP meant too, but I felt the playful need to point out to the OP that round thingies should be used. :smile:
Oh, of course. Round thingies should always be used. Or square thingies, they work too.
[xy]^2 = (ab)^2.
a^2-b^2 =0
<=> (a-b)(a+b)=0
<=> a=b or a=-b
Femme_physics said:
If
xy2 = ab2
Femme_physics,
By chance, you don't mean (xy)2 = (ab)2, do you?
Assuming you mean (xy)^2 = (ab)^2, xy does not neccesarilly equal ab:
sqrt[(xy)^2] = sqrt[(ab)^2]
then
(+/-)xy = (+/-)ab
which is true for only two out of four cases:
+xy=+ab
-xy=-ab
But, you wind up with problems when -xy = +ab and +xy=-ab.
Hope that helps a little.
Alex1812 said:
Assuming you mean (xy)^2 = (ab)^2, xy does not neccesarily equal ab:
then
(+/-)xy = (+/-)ab
+xy=+ab
-xy=-ab
I did not assume the OP meant {if [itex](xy)^2 = (ab)^2[/itex], does [itex]xy = ab[/itex]. I approached it as written {if [itex]xy^2 = ab^2[/itex] does [itex]xy = ab[/itex]} which is false. Without proving it, by testing empirically, it becomes obvious it is false.
However if we assume it the first way, I don't see 4 cases, only 2, but that is sufficient to show the two equations are not equal (see below cases iii and iv, resolve to i and ii. Below my designation for case and equation numbering are interchangeable).
(i) xy = ab
(ii) xy= -ab
(iii) -xy= ab; multiply eq. by -1, you get xy= -ab (which is eq. ii)
(iv) -xy = -ab; multiply eq. by -1, you get xy = ab (which is eq. i )
You're right Ouabache, I didn't bother equating the pairs of equations to reduce it to two cases.
As written,
if (xy^2)=(ab^2)
then (x/a) = (b^2/y^2)
if xy=ab
then (x/a)=(b/y)
Then the original statement is true only iff (b/y)=(b^2/y^2)=((b/y)^2) which, as previously pointed out, is only true iff b=y.
And apologies for my ignorance of TeX.
Alex1812 said:
if (xy^2)=(ab^2)
if xy=ab
then (x/a)=(b/y)
not true if y =0 and x = 0
That's true. Always good to keep in mind the impact of nul denominators. Anyway, I think we've disproven this more ways than Femme_Physics has time to read about lol
  • · Replies 18 ·
