I'm not getting what Kepler's Third Law is about
R^3/T^2 is a constant that illustrates the relationship between a planet's distance from a star and its orbital period. This relationship applies universally across the solar system, as demonstrated by the equations for Earth and Mars, where T^2/R^3 remains consistent. The principle is rooted in gravitational forces that decrease quadratically with distance, particularly when considering small masses relative to the central star. This consistency reinforces the understanding of planetary motion and orbits. Overall, the discussion affirms that R^3/T^2 is not merely a coincidence but a fundamental aspect of celestial mechanics.
victorhugo
How R^3/T^2 is a constant, or is it just the simple relationship between the distance between a planet to a star in a solar system and the period for that planet to orbit the star?
Science news on Phys.org
It's a constant for the whole solar system. For example, suppose ## R_e ## is the semimajor axis of Earth's orbit, ## T_e ## is the period (i.e., 1 year in this case), ## R_m## is the semimajor axis of Mars's orbit, and ## T_m ## is the period for Mars (1 Martian year). Then we have ##T_e^2/R_e^3 = T_m^2/R_m^3 ##.
I found wikipedia's explanation quite satisfying. The relation holds for all forces that quadratically decline with distance and small masses compared to the central sun's mass.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
