Imaginary numbers entertwined with quadratics
The discussion centers on finding a quadratic equation given a pair of complex roots, specifically 2i and -2i. The process involves using the relationship that if r1 and r2 are the roots, the quadratic can be expressed as (x - r1)(x - r2) = 0. Participants clarify that expanding this expression leads to the standard form ax^2 + bx + c = 0. The conversation also touches on the importance of recognizing the properties of complex numbers, particularly that i^2 = -1. Ultimately, the thread emphasizes the method of deriving the quadratic equation from its roots, confirming the approach with examples.
runicle
Hi, I'm not sure if this is calculas based or algebra based so here's the question.
For each pair of roots find a quadratic equation. Express your equation in the form of ax^2+bx+c=0
(A) 2i, -2i
For this question i don't know what is being asked so i guess the pairs could be x...
I know this:
ax^2+bx+c, a(x-h)^2+k and a(x-s)(x-t)
So the problem is how can i use the things that i know to answer the question. If you can please use analogies and don't give me the answer i just need to know what to do.
Think about the process you go through to solve a quadratic and apply it in reverse. Take note of the complex numbers though.
-Hoot:smile:
Note to mentors/admin suggest moving this thread to pre calc forum.
Im trying this... I just used (a+bi)(c+di)
-(a+bi)(c+di)=0
-ac+adi+bci+bdi^2=0
-from previous question 2i, -2i I represented a = 0... and so forth
Although i don't know what 2i represents... Is it x b c?
From what I can see the solution is pretty simple
(x - (2i))(x - (-2i)) = 0
or am I missing something?
Remember that i^2 = -1
[EDIT] I've edited my post to change my stupid mistake
I doubt that hootenay... I'm thinking of x = -b -+ Square root of b^2-4ac over 2a equation and deriving it so that something will occur... I am confused...
Like hoot implied(I think slightly incorrectly), it's always true that if r1 and r2 are the two roots to a quadratic then the characteristic quadratic equation is (x-r1)(x-r2)=0. Then you just expand that to get it into the standard form.
The same argument can be extended to higher degree polynomial equations.
My davey jones's locker i think I've got It!
Correct me if I'm right
0=(x-(2x))(x-(-2x))
0=(x-2i)(x+2i)
0=(x^2+2ix-2ix-4i)
0=(x^2+4)
am i correct?
now if the pairs were 1+3i, 1-3i I would have sub the same way like
0=(x-(1+3i))(x-(1-3i))
0=(x-1+3i)(x+1-3i)
and solve from that correct?
Are you correct?
It is very easy to check your work. What are the roots of
x^2 + 4 =0 ?
0=(x-1+3i)(x+1-3i)
You made a small mistake when going from the first line to the second line. Your second line should reads:
0 = (x - 1 - 3i) (x - 1 + 3i).
Now just expand all the terms out, simplify it, and it's all done.
Can you go from here? :)
