Impact of Current loading for voltage multiplier
shaikss
Hi,
Can you please let me the impact of current loading for the attached circuit?
The attached circuit is a 4-stage dc-dc converter- charge pump.
When I give an input voltage of 1V, the output voltage is around 4.6 V using cadence simulations. The expected output voltage is 5V.
I am able to understand and see the increase in the output voltage from stage to stage.
But I am unable to understand the impact the current loading.
I have attached the circuit and the plots which I got.
Can you please let me know the effects of current loading of the above circuit?
  • Schematic of a four-stage charge pump with MOSFET switches MD1 to MD4, MS1 to MS4, MN1 to MN4 and MP1 to MP4, pumping capacitors C1 to C4, a bypass device MD5, output capacitor C5 and a dashed box marked MD0 replaced with auxiliary MOSFET M1 to M3, driven by Clk1 and Clk2.
  • graphs.doc
    graphs.doc
This happens with most or all capacitor filter systems.
The output capacitor is only charged briefly by the rectified DC, and during the rest of the cycle, the capacitor discharges into the load. This causes "ripple" on the output. This is a DC output that has a varying component on top of it.
So, what you measure is the average value of the DC output, plus ripple.
Ths solution is to use larger capacitors.
