Impulse from basket ball against ground at an angle
To calculate the impulse delivered to a basketball by the court, it's essential to recognize that impulse equals the change in momentum. The basketball, weighing 0.60 kg, hits the court at a speed of 6.5 m/s at a 50° angle from the vertical and rebounds with the same speed and angle. The x-component of the velocity remains unchanged, while the y-component reverses direction, resulting in a change in the y-velocity. This change can be expressed as Δv = -2v, where v is the vertical component of the initial velocity. Thus, the impulse can be calculated using the change in momentum associated with the vertical component of the ball's motion.
okscuba45
To basketball player bounces the 0.60-kg basketball to another player by bouncing it off the court. The ball hits the court with a speed of 6.5 m/s at an angle of 50° from the vertical. If the ball rebounds with the same speed and angle, what was the impulse delivered to it by the court?
I know that Impulse is the change in momentum, or the force times the change in time.
I cannot figure out how to find the Impulse with simply the velocity an angles. Is there a change in momentum if all it does is change direction? If so, how do I use the angles to calculate the change?
I try doing the x/y components of the velocity but it seems to cancel out.
You must use xy components. There is no change in the x velocity, so no impulse. But there is a change in the y velocity - it reverses direction so you'll have something like Δv = -v - v = -2v. Of course you know the number for v, the vertical component of the 6.5 m/s.
