al onestone
- 59
In the ZWM study of 1991 Mandel et al get coherence between the signal photons of two distinct downconversion sources. This is shown with an interference collection between the two possible sources of signal photons (even though they are entangled with the idler). This is achievable because the two downconversions are pumped by a common source which is beamsplit, and because the idler from one downconversion crystal is transmitted through the other downconversion crystal and superimposed with the second idler (made indistinguishable). Thus the name of his paper "Induced coherence without induced emission".
Is it possible to get coherence between two distinct sources of signals (without the transmission and superimposing of the two idlers) if you simply add the two idlers at a beamsplitter to make them indistinguishable (which negates the which-path information)? You would have to look for interference between the two signals in the same way as you would look for interference between any two separate indistinguishable sources of photons (Hull 1949, Pfleegor & Mandel 1967). You can "postselect" the observations that are in phase or you can look for temporal interference between two detectors.
A more thorough explanation of this thought experiment is at http://modifiedzwm.webs.com
