In night vision equipment, how does 'information' transfer?
The discussion revolves around the mechanisms of information transfer in night vision equipment, particularly focusing on how infrared light is converted into visible images. Participants explore the similarities and differences between night vision technology and digital cameras, as well as the underlying processes involved in image sensing and representation.
  • One participant describes their understanding that infrared light is converted into electrons and then into visible light, questioning how information such as shapes and movement transfers between photons and electrons.
  • Another participant suggests that the information transfer occurs similarly to digital imaging, where light falls on an image sensor, is digitized, and can be reproduced.
  • A participant expresses confusion regarding the relationship between digital cameras and night vision technology, indicating a lack of understanding of digital camera operation.
  • It is noted that all digital imaging sensors operate on similar principles, absorbing photons and converting that energy into electron activity, although the specifics may vary.
  • One participant elaborates on the components of imaging devices, explaining the role of optics and sensors in capturing and transferring information from light to a digital format, likening it to a map of intensity measurements.
  • References to various types of sensors, including CCD, CMOS, and image intensifiers, are provided, highlighting differences in their operation.
Participants express differing levels of understanding regarding the relationship between night vision and digital imaging technologies. While there is some agreement on the basic principles of information transfer, the discussion reveals uncertainty and varying interpretations of the mechanisms involved.
Some participants demonstrate a lack of familiarity with digital camera technology, which may affect their understanding of night vision systems. The discussion includes references to specific sensor types without delving into the detailed mechanics of each.
Calconceptofnumber1
So I read a couple of explanations of how night-vision equipment works. Unfortunately I don't remember the sources but my recollection/understanding is that infrared light is converted into electrons and then into visible light. So my question is how does the information by which I mean (the shapes, the visible movement and the shades) transfer between two different though as I understand it linked particles ,the photon the electron?
Science news on Phys.org
Pretty much the same way it does in any other digital imaging.
Light falls on the image sensor the resulting signal is digitised and then can be saved or reproduced on the cameras rear LCD panel
do some googling on how a digital camera works
BTW unless your are really a university post graduate, I don't think your thread deserves an A tag :wink:
and if your are a post grad. then you should be well used to doing research on a subject :smile:
Dave
I was unaware that digital cameras and night vision were the same concept, and i'll admit that I don't really understand how digital cameras work so I'm unlikely to gravitate towards them very quickly. I filled out my educational history on my profile so you could quite easily read that there. Because the concept seemed a lot more complicated to me than it actually is I presumed it was at a higher level than it was.
Yes but you selected A for the subject level. We assume you know what you are doing when you make that selection and thus there is no reason for us to look at your profile. I see that you're new so I'm guessing that you are not yet used to the levels.
Essentially all digital imaging sensors use similar concepts. They absorb incoming photons and use that energy to make electrons do something. The details of how each type of sensor works are slightly different, but the basic idea is the same.
There are two basic pieces for any imaging device. You have the optics portion, and you have the sensor portion. The optics portion for every device is virtually the same. A series of optical components (lenses and/or mirrors) gather incoming light from the target region and focuses it so that light from any single point in object space (the region you're looking at with the optics) is concentrated at a single point on the image plane (or focal plane). This collection of points containing focused light is called an 'image'.
The light then falls onto a sensing device placed at the image plane and is absorbed. The shape, color, and all other information you can gather from an image is contained in the image (though your sensor may not be able to record all of this different information at once). The sensor then takes that light and uses its energy to do something else. For most digital sensors, a small pixel measures the intensity of light falling on it. Fitting together the measurements from millions of pixels gives you a 'map' of the image. By 'map' I mean that the original information has been taken from the image and transferred to another medium, in this case a large array of intensity measurements, just like a map of a city contains the information about the position and layout of buildings, roads, and other features you would encounter if you went to that city. You can think of a digital image as a large excel spreadsheet with each cell holding a number that indirectly represents the intensity of the light in that region of the image. A traditional photograph from film holds the information in the layout of the dyes used to make the image.
The exact mechanisms that take the information contained in the light and move it over to electrons in a digital sensor varies, like I said above. But the most common sensors are CCD and CMOS sensors. I'll post a link to both of these devices below, along with a few other links that may help. Infrared sensors often use something called an image intensifier, which works a little differently from CCD and CMOS sensors.
Here you are:
https://en.wikipedia.org/wiki/Image_sensor
https://en.wikipedia.org/wiki/Digital_imaging
https://en.wikipedia.org/wiki/Charge-coupled_device
https://en.wikipedia.org/wiki/Active_pixel_sensor
https://en.wikipedia.org/wiki/Image_intensifier
https://www.explainthatstuff.com/hownightvisionworks.html
  • · Replies 17 ·
  • · Replies 24 ·
