Inclined Plane Problem Two Parts
The discussion revolves around solving an inclined plane physics problem involving a block sliding down a frictionless surface at an angle of 24.5°. The initial calculation for acceleration was incorrectly derived, leading to confusion about the application of Newton's second law. The correct approach involves resolving the gravitational force into components parallel and perpendicular to the incline. The final speed of the block at the bottom of the incline was calculated using the incorrect acceleration, prompting a need to reassess the force components. Understanding how to properly calculate these components is crucial for solving the problem accurately.
sugarntwiligh
The block shown in Fig. 4-48 lies on a smooth plane tilted at an angle θ = 24.5° to the horizontal. Ignore friction.
http://www.webassign.net/giancoli5/4_48.gif (visit this site for picture)
(a) Determine the acceleration of the block as it slides down the plane.
(b) If the block starts from rest 9.50 m up the plane from its base, what will be the block's speed when it reaches the bottom of the incline?
a.)
9.8/sin(24.5)=23.6 m/s^2 which is the acceleration down the slope where the x=ma and the y=mg. Is this correct? It feels like I am forgetting something...
b.)
From the equation v^2=vi^2+2ad,
v^2=0+2*23.6*9.5
v=21.2m/s at the bottom of the incline.
sugarntwiligh said:
a.)
No, it's not. What forces act in the x direction? Apply Newton's 2nd law. (Sanity check: Compare your calculated acceleration with g. Does your answer make sense?)
b.)
v^2=0+2*23.6*9.5
If you had the correct acceleration, that approach would work.
I didn't use any value of x in my equation. But I am still confused about why its wrong, because sin(24.5)=(9.8m)/(ma). Where mg is the opposite and ma is the hypotenuse. And then solving for a gives me the same answer.
My answer would make more sense if I did 9.8sin(24.5)=4.06, and I think this is the right way to go, but why?
To use a triangle to find force components, you must realize that the total force is "mg", so mg must be the hypotenuse of your right triangle. (That right triangle is not simply the incline.)
You need to learn how to find the components of the weight parallel and perpendicular to the incline surface. Read this: http://www.glenbrook.k12.il.us/gbssci/Phys/Class/vectors/u3l3e.html"
Ohhhhhhhhh I get it! Thanks!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
