Incorrect amps showing on multimeter?
  • Thread starter Thread starter jdmmade
    Amps Multimeter
The discussion centers on a circuit with a 3-volt supply, a 330-ohm resistor, and a red LED, where the measured current is 3 mA instead of the expected 9 mA based on Ohm's law. The discrepancy is attributed to the voltage drop across the LED, which affects the overall current in the circuit. Calculations show that the voltage drop across the resistor is approximately 1 volt, leaving 2 volts across the LED. To increase the LED's brightness to 15 mA, a resistor of about 68 ohms is recommended to achieve the necessary voltage drop. Understanding the impact of load on current measurements is crucial for accurate circuit design.
jdmmade
Okay so here's what I am dealing with. I created a circuit with 3 volts and used a 330 ohm resistor and a simple red LED, and using my multimeter I tested for the current. Now using ohms law:
3/330 = 9 mA... now what I see over the multimeter is 3 mA. I must have calculated something wrong or something is different with in the circuit. Maybe because a load is there, the calculations totally change?
There will be a voltage drop across the LED.
You can calculate it like this:
Current in 330 ohm resistor = 3 mA or 0.003 amps
Voltage dropped across 330 ohm resistor = iR = 0.003 * 330 or 0.99 volts. Call it 1 volt.
So the voltage across the LED is 2 volts (3 - 1 is 2) . Diiferent coloured LEDs have different voltage drops.
So, to make the LED light up a lot brighter, you need to send more current through it.
Let us say 15 mA. So we need a resistor that will drop 1 volt when it has 15 mA flowing in it.
This is R = 1 volt / 0.015 amps = 66.6 ohms. You can get 68 ohm resistors and that would be OK.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
