Incorrectly connected system or bad power meter help please?
Using three power meters to measure a three-phase resistive load, one meter displayed a reactive power value despite all showing a power factor of 1.00. This discrepancy raises concerns about the accuracy of the meter or potential issues with the setup. Participants suggest providing a sketch of the system to clarify the connections and identify possible faults. Understanding the configuration is crucial for diagnosing the problem effectively. Accurate measurements are essential for ensuring proper system functionality.
Physicist3
Hi,
When using 3 power meters to measure a 3 phase resistive load, I found that each of the power meters showed a pf of exactly 1.00. However, on one phase I was getting a reactive power value. How is this possible? Is this likely to be the sign of a faulty meter or similar?
Physicist3 said:
Hi,
Could you post a sketch of the setup? Include the power source, how the meters are connected, and what instrument you are seeing a "reactive power value" on...
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
