Increasing the Range of Howitzers
- Thread starter chemisthypnos
- Start date
66 replies · 13K views · last reply
- 1,293
gary350 said:...heaver bullets maintain speed longer but gravity pulls them down sooner.
- 612
I think what he's trying to say is that with a heavier bullet, the muzzle velocity is slower so the time of flight out to a fixed range is longer. Since you usually don't care about how much the bullet drops in a given time, you care how much it drops at a given range, this means that a heavier bullet suffers more bullet drop (but retains a higher percentage of initial velocity and energy).Melbourne Guy said:Does gravity work like that, @gary350? I thought things fall at the same rate, irrespective of their mass, so wouldn't it be some other factor reducing their range (if that's the outcome, I think that's what you're saying)?
Stormer
- 121
- 23
Why are artillery guns still rifled? You would think it would be cheaper to manufacture and it would get higher muzzle velocity and longer ranges with a smooth bore barrel and discarding sabot fin stabilized projectiles like in anti tank guns.
- 612
Sure, you could do that, but that significantly decreases the size of projectile (and thus quantity of explosive filler). In addition, spinning a projectile tends to reduce dispersion compared to a fin stabilized non-spinning one, though you could angle the fins a bit to induce spin that way.Stormer said:Why are artillery guns still rifled? You would think it would be cheaper to manufacture and it would get higher muzzle velocity and longer ranges with a smooth bore barrel and discarding sabot fin stabilized projectiles like in anti tank guns.
That having been said, some guided artillery rounds with pop-out fins do exist (such as the M982 Excalibur), and if those become close to ubiquitous in the future, smoothbore could end up being a possibility. They are quite expensive though, so I'm not sure they'll ever entirely replace older style unguided shells.
- 11,327
- 8,758
The word entirely is perhaps too broad.cjl said:They are quite expensive though, so I'm not sure they'll ever entirely replace older style unguided shells.
I think it is interesting to watch what happens. If it takes only 1 guided projectile to destroy the target rather than 100 or 1000 dumb ones, then it is probably cheaper, and has fewer incidental victims. The same argument applies to smart bombs, or even to cruise missiles. Expense versus accuracy.
Recent news of another expensive, but highly selective weapon.
https://www.wsj.com/articles/secret...y-terrorists-not-nearby-civilians-11557403411
Secret U.S. Missile Aims to Kill Only Terrorists, Not Nearby Civilians
Weapon doesn’t explode, but brandishes knives to shred target; it was used in high-profile strikes in 2017 and this year
Mentor
- 23,212
- 7,703
Discarding sabot rounds are designed for obtaining and retaining high-velocity for their role of armor piercing. Artillery rounds don't require high velocity and the reduced diameter of the sabot round for a given bore diameter would also reduce the explosive payload of the round.Stormer said:Why are artillery guns still rifled? You would think it would be cheaper to manufacture and it would get higher muzzle velocity and longer ranges with a smooth bore barrel and discarding sabot fin stabilized projectiles like in anti tank guns.
Guided projectiles are great for things like buildings, bunkers, radar stations, and sometimes armored vehicles, but are poor choices for dealing with infantry and large numbers of motorized forces unless they have virtually no air defense.anorlunda said:I think it is interesting to watch what happens. If it takes only 1 guided projectile to destroy the target rather than 100 or 1000 dumb ones, then it is probably cheaper, and has fewer incidental victims. The same argument applies to smart bombs, or even to cruise missiles. Expense versus accuracy.
Stormer
- 121
- 23
Yes they do require high velocity. That is how they get their range.Drakkith said:Discarding sabot rounds are designed for obtaining and retaining high-velocity for their role of armor piercing. Artillery rounds don't require high velocity and the reduced diameter of the sabot round for a given bore diameter would also reduce the explosive payload of the round.
And the reduced diameter can be compensated by having a longer projectile so you get the same payload volume in the shell.
Mentor
- 23,212
- 7,703
No they do not. As an example, the U.S. 155 mm M1 "Long Tom" artillery gun from WW2 has a muzzle velocity of 853 m/s and a modern M777 howitzer has a muzzle velocity of 827 m/s. Most artillery I've looked at has a muzzle velocity around these numbers. In contrast, the General Dynamics KEW-A1 APFSDS round has a muzzle velocity of 1740 m/s, more than twice the M1 artillery shell. Virtually all of the tank KE ammunition on this page have a muzzle velocity around 1700 m/s, far in excess what artillery has.Stormer said:Yes they do require high velocity. That is how they get their range.
A muzzle velocity of around 800 m/s is not considered to be high velocity.
- 3,482
- 1,293
He's not entirely of base here. A higher muzzle velocity, all else being equal, will generally result in a longer range. The M777 with standard dumb ammunition has roughly equivalent (or slightly less) range than shells fired by the M1. Even the rocket-assisted M549 shells only get slightly greater range because there is only so much room at add a propellant without sacrificing space for warhead.Drakkith said:No they do not. As an example, the U.S. 155 mm M1 "Long Tom" artillery gun from WW2 has a muzzle velocity of 853 m/s and a modern M777 howitzer has a muzzle velocity of 827 m/s. Most artillery I've looked at has a muzzle velocity around these numbers. In contrast, the General Dynamics KEW-A1 APFSDS round has a muzzle velocity of 1740 m/s, more than twice the M1 artillery shell. Virtually all of the tank KE ammunition on this page have a muzzle velocity around 1700 m/s, far in excess what artillery has.
The M982 Excalibur has longer range but that's in large part because it is finned, which gives it some limited gliding capability (i.e, it isn't purely ballistic).
I believe the main gun on an M1A2 Abrams firing M829 APFSDS rounds still only has an effective range of about 3 km. It only about about 20% as much as a standard M795 howitzer shell, though, so it's easier to get up to those speeds but will slow down more quickly due to drag versus a heavier projectile of the same form. It's not apples-to-apples.
Having said all of the above, you can't just go about making artillery rounds shaped like broom handles to try to get the same mass of high explosive, either. The shape of the explosive can matter as much as the quantity. It can affect any shaping the designer wants to do with the blast (e.g., make sure energy is directed toward a target and not everywhere all at once) and can affect aerodynamic stability.Stormer said:Yes they do require high velocity. That is how they get their range.
There's also a question of how to transport and load something like that. Breach loading a long rod means you would have to reduce the elevation of your howitzer to fit the shell in the back if it gets too long. That uses up valuable time when rate of fire is a concern.
You'd also have to consider that a longer projectile with a discarding sabot will either have less barrel to travel or would require a longer barrel to make optimal use of the propellant.
Mentor
- 23,212
- 7,703
Certainly, but the fact remains that artillery doesn't achieve its range by being high-velocity, because it isn't high-velocity. The 700 - 900 m/s 'standard' muzzle velocity range seems to be a sweet spot where you get enough velocity for long effective range while keeping the amount of required propellant and barrel wear to an acceptable level, along with tolerable gun construction costs. To go up in velocity you either need to increase the amount propellant and/or barrel length, which are both serious considerations to take into account, or make your projectile lighter, which reduces its damage potential.boneh3ad said:He's not entirely of base here. A higher muzzle velocity, all else being equal, will generally result in a longer range.
Rifled guns firing shells with a muzzle velocity of around 800 m/s are the standard for a reason.
I think the main issue with the Abrams APFSDS round is that it is a fundamentally different type of round than the common artillery rounds. The APFSDS round is designed to penetrate armor using its very high speed. So it has to be nearly pinpoint accurate to hit a relatively small target (vs the use of artillery for area suppression) AND has to retain enough velocity to penetrate an armored vehicle. These two requirements are what limit its effective range, though not its maximum range. The table below shows the velocity of several APFSDS rounds vs range:boneh3ad said:I believe the main gun on an M1A2 Abrams firing M829 APFSDS rounds still only has an effective range of about 3 km. It only about about 20% as much as a standard M795 howitzer shell, though, so it's easier to get up to those speeds but will slow down more quickly due to drag versus a heavier projectile of the same form. It's not apples-to-apples.
As you can see, the rounds are all still well above 800m/s even out to 10km+ in range. However, they've lost roughly 3/4 of their kinetic energy by this point, making them far less effective at penetrating their target's armor. Even dropping from 1700 m/s to 1400 m/s is a reduction of about 1/3 kinetic energy and penetrating power, so by the time the round reaches 4 km it is already substantially less effective.
Finally, the very design of any high-velocity sabot-based round is fundamentally at odds with artillery shell design. Artillery shells want maximum destructive power (or maximum utility for things like smoke or illumination rounds) for a given size, which is achieved by packing as much explosive or other material as possible into the shell. A high-velocity round, especially a sabot-based design, typically does the opposite. It reduces the size and weight of the projectile in order to get that increase in velocity and retain it. Great for KE penetrators, not so great for most everything else. Sure you can make the projectile longer, but then you've just increased the mass again, which brings the velocity back down.
APFSDS rounds aren't high velocity because of their sabot design, they are high-velocity because the round and sabot are extremely lightweight. The M1 Abrams 120mm M829 round has a combined sabot and subprojectile mass of 7.1 kg, of which 4.3 kg is the subprojectile itself. Compare this with the M830 HEAT round which has a projectile weight of 13.5 kg, nearly twice that of the M829 sabot+subprojectile, and a muzzle velocity of 1140 m/s. The M829 also uses 8.1 kg of propellant vs 5.5 kg for the M830. Half the weight plus 50% more propellant is required to get the M829 round up to 1670 m/s vs 1140 m/s using the same gun.
Edit: Forgot to add the M830 muzzle velocity. Added now.
Stormer
- 121
- 23
I thought the point of artillery is to affect a area, so a equal dispersion of frag going in every direction.boneh3ad said:The shape of the explosive can matter as much as the quantity. It can affect any shaping the designer wants to do with the blast (e.g., make sure energy is directed toward a target and not everywhere all at once) and can affect aerodynamic stability.
And aerodynamic stability is the reason a long slender sabot dart can be shot accurately without spin stabilization. A normal artillery shell on the other hand would tumble without spin stabilization.
If you are using a brass case anyway the total length does not have to be so much longer because you can put the sabot projectile all the way down to the bottom of the case with the propellant around it just like in a saboted tank shell.boneh3ad said:Breach loading a long rod means you would have to reduce the elevation of your howitzer to fit the shell in the back if it gets too long.
I also think a slim sabot artillery shell with the same weight as a normal artillery shell would get a better ballistic coefficient and that alone would give it a longer range, plus the higher speed because of no losses going to spinn up the projectile. And all of that with a cheaper barrel to make because of no rifling, and probably a longer barrel life too because of the lack of rifling.
Mentor
- 23,212
- 7,703
Okay. Let's say you have a barrel that's 150 mm inner diameter. What are the dimensions of your sabot shell? How much explosive does it have in it? What is its approximate muzzle velocity? How does it compare to a normal artillery shell of roughly 150 mm?Stormer said:I also think a slim sabot artillery shell with the same weight as a normal artillery shell would get a better ballistic coefficient and that alone would give it a longer range, plus the higher speed because of no losses going to spinn up the projectile. And all of that with a cheaper barrel to make because of no rifling, and probably a longer barrel life too because of the lack of rifling.
- 3,482
- 1,293
Sure, but that doesn't include up and to the sides. If you have a long, rod-shaped projectile, it would be difficult to shape a charge that does anything other than send shrapnel out horizontally when detonated at ground level, when what you really want is an air burst that sends a cone of shrapnel down over a wide area.Stormer said:I thought the point of artillery is to affect a area, so a equal dispersion of frag going in every direction.
You still have to carefully balance that projectile to make sure it is stable, which is not a given if you also have to pack a warhead in there.Stormer said:And aerodynamic stability is the reason a long slender sabot dart can be shot accurately without spin stabilization. A normal artillery shell on the other hand would tumble without spin stabilization.
Stormer said:If you are using a brass case anyway the total length does not have to be so much longer because you can put the sabot projectile all the way down to the bottom of the case with the propellant around it just like in a saboted tank shell.
Let's test this theory:
- The penetrator for an M829 APFSDS weighs 4.6 kg and is 68.4 cm long and 2.7 cm in diameter, so the aspect ratio is 25.3. It also has 11.9 kg of propellant and casing.
- The M795 howitzer shell weighs 47 kg, 10.8 kg of which is high explosive.
[tex] L = \left(\frac{4V(AR)^2}{\pi}\right)^{1/3},[/tex]
which results in a shell that is 174.7 cm long. That's already 1/3 the length of the barrel of the M777. Here's the kicker: you can't just shape the explosive like the penetrator because it's the casing that produces the blast frag effect for an artillery round. I don't have number for how much the casing on an M795 weighs, but it's the majority of the remaining weight of the shell since the propellant charges are separate. Let's assume it's 80% of the remaining 36.2 kg, so about 29 kg of high-frag steel casing. That has to surround the high explosive. It has a density of about 7.85 g/cm3, so the volume is 3694.3 cm3. That makes the total volume of the projectile 10,022 cm3, leading to a length of 203.0 cm. with a diameter of 8.0 cm. That's about 40% the length of the M777 barrel.
Now let's assume the ratio of projectile mass to the total mass of the round (including propellant, casing, and sabot) is the same as for the M829. The M829 weighs 20.9 kg, so is about 43% projectile by mass. This means the above shell with a mass of 39.8 kg would be part of a round whose total mass is 92.6 kg.
So your idea is to launch rods that are taller than an average adult male from a round with a mass that is greater than the average adult male. This is a bad idea for several reasons:
- The round would require de-elevating the howitzer in order to load it, slowing down firing operations.
- The round would not work with existing howitzers, whose barrels are far too short for this.
- The round would require considerably more complicated logistical chains to transport it and deliver it to the battlefield (they are twice the mass and almost 3 times the length but with the same diameter as the M795 in this example).
- The round would require multiple soldiers to lift it and load it into the howitzer, meaning you need more men to man an artillery battery.
- There still isn't likely to be enough room to ideally shape the charge to produce optimal blast frag without further increasing the size and mass.
- 612
That's really all relative though.Drakkith said:Certainly, but the fact remains that artillery doesn't achieve its range by being high-velocity, because it isn't high-velocity.
Higher velocity means longer range, and the recent trend to go to 52 caliber barrels on things like the PzH-2000, Krab, Caesar, and Archer systems or even the 58 caliber barrel on the M-1299 howitzer the US is testing as part of the Extended Range Cannon Artillery program are perfect examples of this. Of course, these are achieving higher velocity by just lengthening the barrel, because as @boneh3ad explained a sabot round would be wildly impractical for a number of reasons, but this extended barrel rather dramatically increases range - from ~24 km with a normal shell and 35-40 with an Excalibur from an M777 up to 35km normal and 60km Excalibur on the PzH-2000. The M1299 has even successfully completed a 70km test shot with the Excalibur.
Of course, there's a balance here with both barrel wear and practicality (longer barrels make the guns more difficult to transport, maneuver, and just generally make everything more awkward), but it certainly seems that the trend has been towards higher velocity and longer range lately, especially based on learnings from the Ukraine war so far.
Stormer
- 121
- 23
Why would you assume that? I would think you want the widest shell possible that can still remain aerodynamically stable and fit in the barrel with the fins (that can be folding). So go as wide as you can until it is starting to show signs of being aerodynamically unstable while still keeping a decent volume for payload, wall thickness and total length with the casing and propellant.boneh3ad said:Let's assume we want the same aspect ratio as the M829 penetrator in the form of a howitzer projectile.
And when it comes to slender darts and fragmentation just look at Starstreak. The subprojectiles there seems to disperse the fragments just fine. And remember that a artillery projectile will never come 90 degrees straight down to the ground so a radial frag pattern will still hit the ground (but maybe as much as almost half the frag can be wasted by going up in the air and loosing to much energy before it comes falling back to the ground).
Mentor
- 23,212
- 7,703
Starstreak is an anti-aircraft weapon system. Its subprojectiles are designed to physically impact the target and THEN explode. Since they are already inside the target, and the target is a highly complex piece of machinery that can be mission-killed with very little damage, especially from the inside, the required charge and amount of shrapnel is relatively low. Hence you can use a very slender dart-like projectile with only a pound of explosive.Stormer said:And when it comes to slender darts and fragmentation just look at Starstreak. The subprojectiles there seems to disperse the fragments just fine.
Artillery shells are usually designed for area suppression, which requires much larger amounts of fragmentation and explosive.
If you're making the projectile larger, then why have the sabot at all? The entire point of the sabot is to align the projectile with the center of the barrel, capture as much of the force of the propellant as possible, and then drop away so that the thin, high-velocity projectile isn't slowed down by it. That is literally the only point of the sabot. If you're going to make the projectile larger, just make it the same diameter of the bore and be done with it. A sabot doesn't give you high-velocity. A lightweight projectile does.Stormer said:Why would you assume that? I would think you want the widest shell possible that can still remain aerodynamically stable and fit in the barrel with the fins (that can be folding). So go as wide as you can until it is starting to show signs of being aerodynamically unstable while still keeping a decent volume for payload, wall thickness and total length with the casing and propellant.
Note that you don't need a sabot if all you desire is a cheap, smoothbore barrel. They already make artillery shells with fins on them.
That is supported by this article by The Geneva International Centre for Humanitarian Demining (GICHD), entitled Explosive Weapon Effects. From page 52:Stormer said:And remember that a artilleri projectile will never come 90 degrees straight down to the ground so a radial frag pattern will still hit the ground (but maybe as much as almost half the frag can be wasted by going up in the air and loosing to much energy before it comes falling back to the ground).
The angle at which a munition impacts the target has a significant bearing on the size and shape of the lethal area. In simple terms, the higher the angle (toward vertical 90°) of fall, the larger the lethal area will be.51 In order to maximize lethal area, at higher angles of fall (45-90°) the optimal height for detonation is approximately 2 m above ground, although even at just above ground, the lethal area is increased (Jacobsen & Strømsøe, 1968).
Stormer
- 121
- 23
Many AA missiles also have proximity burst. To shower the target with frag.Drakkith said:Starstreak is an anti-aircraft weapon system. Its subprojectiles are designed to physically impact the target and THEN explode.
Because my point was to make a projectile that did not need spin stabilization to be stable in flight. So you don't waste energy spinning the projectile and therefore getting higher velocity and longer range. And also to get rid of the rifling of the barrel to make it cheaper to manufacture and maybe also give it a longer service life. To get a aerodynamically stable projectile without spin stabilization you need to make it higher aspect ratio and therefore a sabot for it not to need so high chamber pressure to get it up to speed. But you do not need as high of a aspect ratio as a APDS to achieve this. Plus the benefit of getting a higher ballistic coefficient with a higher aspect ratio shell than a normal artillery shell will also increase the range.Drakkith said:If you're making the projectile larger, then why have the sabot at all?
Mentor
- 23,212
- 7,703
Stormer said:Because my point was to make a projectile that did not need spin stabilization to be stable in flight. So you don't waste energy spinning the projectile and therefore getting higher velocity and longer range. And also to get rid of the rifling of the barrel to make it cheaper to manufacture and maybe also give it a longer service life. To get a aerodynamically stable projectile without spin stabilization you need to make it higher aspect ratio and therefore a sabot for it not to need so high chamber pressure to get it up to speed. But you do not need as high of a aspect ratio as a APDS to achieve this. Plus the benefit of getting a higher ballistic coefficient with a higher aspect ratio shell than a normal artillery shell will also increase the range.
I'm not sure what else to say that hasn't already been said. Choice of projectile shape and size varies widely and takes many factors into account. Standard artillery shells that are spin stabilized have advantages in cost and damage potential, while other rounds have advantages in other areas like range and accuracy. I question whether the advantages of a smoothbore, sabot-based round are worth the added cost and complexity of the rounds and the reduced damage potential. Saving $10,000 per gun (or whatever amount) is all fine and good, but if you're spending 10x more on ammunition you might not be saving anything at all.
- 3,482
- 1,293
Stormer said:Many AA missiles also have proximity burst. To shower the target with frag.
- AA missiles have a very different propulsion mechanism, a very different deployment vehicle, a very different target, and a very different logistical chain than artillery shells. Grenades also shower a target in frag but that is also not relevant here.
- AA missiles are not as long and slender as an APFSDS penetrator, and even when they are, their size is so much larger that they can still fit plenty of fancy explosives inside.
Stormer
- 121
- 23
Yes. But the topic of this thread was to increase the range of artillery. If other aspects like damage potential suffers that is a different topic. And you can have different shells to preform different tasks. And that is another advantage of going with a sabot shell, because that way you still keep the caliber of the gun so you could also shoot a traditionally shaped shell with the same gun with finns to impart the spinn on it for stabilization. So you could have the same smoothbore gun and use the traditional shaped but finned shell for shorter ranges, and use the longer non spinning sabot shell for longer range targets.Drakkith said:Standard artillery shells that are spin stabilized have advantages in cost and damage potential, while other rounds have advantages in other areas like range and accuracy.
- 3,482
- 1,293
Is it even an artillery shell if it can no longer perform the basic duties of an artillery shell?Stormer said:Yes. But the topic of this thread was to increase the range of artillery. If other aspects like damage potential suffers that is a different topic.
On the other hand, you could make a shell of approximately the same size with, say, a ramjet integrated into it and keep the same supply chain and logistics processes in place and use the same guns while still greatly increasing range. It has an advantage over rocket-assisted artillery shells in that it does not carry its oxidizer along with it, leaving more space for payload (though with a loss of some space for the flow path). It's a win-win.
The US Department of Defense is funding exactly that:
https://www.defensenews.com/miltech/2022/08/11/boeing-nammo-test-ramjet-155-artillery-weapon/
- 2,938
I'm a bit late to the party with this, but be careful with those darts as references. That whole system is optimized to give insane single point penetration at close (few km) range, and there is very little thought given for anything above 5km.Stormer said:I also think a slim sabot artillery shell with the same weight as a normal artillery shell would get a better ballistic coefficient and that alone would give it a longer range,
Also, don't get carried away with those long darts
- 1,293
...to the last I grapple with thee; from hell's heart I stab at thee; for hate's sake I spit my last breath at theeRive said:I'm a bit late to the party with this, but be careful with those darts as references. That whole system is optimized to give insane single point penetration at close (few km) range, and there is very little thought given for anything above 5km.
Flyboy
- 633
Part of that is also the nature of modern armored combat. Beyond that range, the tank sensors and drew may have difficulty picking out their targets on the battlefield, unless you're up on a ridgeline, hull down in a revetment, and your enemy is making a blind charge across open terrain without artillery or air support.Rive said:I'm a bit late to the party with this, but be careful with those darts as references. That whole system is optimized to give insane single point penetration at close (few km) range, and there is very little thought given for anything above 5km.
A proper scenario would probably include things like smoke rounds deploying curtains of smoke to obscure visibility, VT/prox fused artillery barrage of known/suspected tank and infantry emplacements, maybe even MLRS salvos deploying shaped charge and anti-personnel submunitions. If your enemy is really capable, they may even be using standoff air launched ordinance to glide silently over your position and deploy sensor fused weapon submunitions on your position to really ruin your day.
If you're having a good day, you can expect to be making engagements with a modern MBT at 3km tops. Usually that's a third of that or less.
As for the idea of subcaliber tube artillery... I can think of a single practical use for it: extremely long-range strike against a fixed, hardened target like a command and control bunker or similar. But it's a very niche role, that depends heavily on being able to pack the requisite GPS guidance into the round, and knowing exactly where the bunker is, and hoping it's shallow enough you can punch into it.
If you want to hit someone with artillery at a great distance, rockets or missiles are absolutely the way to go. Hell, take a page from the US and slap a small GPS-guided glide bomb atop an existing rocket, give it the target, and just yeet that thing as high and far as you can, then glide from there.
sbrothy
- 1,575
Long range howitzers are smoothbore exactly because rifling converts some of the projectile's energy to rotation. I read this recently but dont remember where. Must be easy to verify though.Stormer said:Why are artillery guns still rifled? You would think it would be cheaper to manufacture and it would get higher muzzle velocity and longer ranges with a smooth bore barrel and discarding sabot fin stabilized projectiles like in anti tank guns.
Apropos I also seem to remember that both the US and China has fielded naval railguns. There are some impressive videos on youtube.
Mentor
- 23,212
- 7,703
I'd say 'tested' instead of 'fielded'. None of these weapons are in operational status as far as I know, and I believe the U.S. Navy has postponed or stopped further research and development on railguns for the moment.sbrothy said:Apropos I also seem to remember that both the US and China has fielded naval railguns. There are some impressive videos on youtube.
sbrothy
- 1,575
You may well be right. Something about the gun's inability to keep shooting no?Drakkith said:I'd say 'tested' instead of 'fielded'. None of these weapons are in operational status as far as I know, and I believe the U.S. Navy has postponed or stopped further research and development on railguns for the moment.
edit: https://www.defensenews.com/naval/2...-futuristic-railgun-eyes-hypersonic-missiles/
Also railguns are for space. Can it even fire over the horizon. Nah this one is truly nuts:
Project Thor
Also recently read Stross' Singularity Sky. Concepts like "directional spallation" and "prefragmented copper needles" stuck in one's head. He's good fun.
High School
Increasing the brightness of an OLED pixel
- jebez
- · Replies 19 ·
- Optics
- Replies
- 19
- dansmith170
- · Replies 1 ·
- Optics
- Replies
- 1
- Tony Hau
- · Replies 5 ·
- Electrical Engineering
- Replies
- 5
- simphys
- · Replies 18 ·
- Introductory Physics Homework Help
- Replies
- 18
- Basmah
- · Replies 1 ·
- Nuclear Engineering
- Replies
- 1
- member 731016
- · Replies 10 ·
- Calculus and Beyond Homework Help
- Replies
- 10
Graduate
Increasing the COP and the heat pump
- Pisica
- · Replies 6 ·
- Thermodynamics
- Replies
- 6
- laser1
- · Replies 23 ·
- Replies
- 23
- BRN
- · Replies 3 ·
- AI and Computer Science
- Replies
- 3
- Sphere
- · Replies 16 ·
- Mechanics
- Replies
- 16
