What is the Distribution of Z When X and Y are Independent N(0, 1) Variables?
Z, defined as the sum of two independent N(0, 1) random variables X and Y, follows a normal distribution with a mean of 0 and a variance of 2. The density function of Z can be derived from the characteristic functions of X and Y, leading to the conclusion that Z is normally distributed. Additionally, the expected value E[Z|X > 0, Y > 0] equals 2. To verify this, one can set up a ratio of double integrals in x and y and convert to polar coordinates. The discussion emphasizes the importance of including both mean and variance in the final answer.
johnny872005
Hi Guys.
I'm trying to understand how to solve the following problem. Any help and explanation would be greatly appreciated!
thanks.
Let X and Y be independent N(0, 1) random variables and let Z = X + Y.
What is the distribution of Z? Write down the density function of Z.
Also:
Show that E[Z|X > 0, Y > 0] = 2
Have you learned about characteristic functions(cf)? If so then you get the cf of Z is the product of the cf's of X and Y. The cf of Z is then exp(-t2), so that Z is normally distributed with a variance of 2.
For the last question, set it up as a ratio of double integrals in x and y. Then convert to polar coordinates. It should be tedious, but workable.
If X~N(m1,s1^2) and Y~N(m2,s2^2) indeply, then
X(+-)Y ~ N(m1(+-)m2,s1^2+s2^2), it is easier to check from mgf or cf.
I'm still somewhat confused. What would you say as the final answer to the two questions I have above...?
If you could just list something like:
answer: thefunc
reason: because x y and z
Sorry if it seems bossy, I'm just really confused now after reading the above.
thanks
It's hardly possible to state the answer to 1) more explicitly.
No, you have to add 'and mean=0'. LOL.
O.k., you're right, of course.:smile:
