What is the Integral of a Trigonometric Function with an Indefinite Integral?
The integral of the function \(\int \frac{cos x}{sin^2(x) - sin(x)-6}\) can be simplified by factoring the denominator into \((sin(x) - 3)(sin(x) + 2)\). Substituting \(u = sin(x)\) and \(du = cos(x) dx\) allows for the integral to be rewritten as \(\int \frac{du}{(u-3)(u+2)}\). After applying partial fractions, the result is \(\frac{1}{5} ln(\frac{sinx-3}{sinx+2}) + C\). The importance of including the constant of integration \(C\) is emphasized, as it can affect grading.
planauts
\int \frac{cos x}{sin^2(x) - sin(x)-6}2. The attempt at a solution
I first tried factoring the denominator.
\int \frac{cos x}{(sin(x) -3)(sin(x)+2)}
The first thing that came to my mind was Partial Factoring but I don't think it would work in this case.Thanks in advance!
I would start by substituting u=sin(x) and then worry about the partial fractions in the variable u.
Let:
u = sin(x)
du = cos(x) dx
After doing Partial Fractions, I ended up with:
\frac{1}{5} ln(sinx-3)-\frac{1}{5} ln(sinx+2)
Thanks for your help. I think that is the correct answer.
planauts said:
Let:
u = sin(x)
du = cos(x) dx
Also note you can factor out a 1/5 and you get:
planauts said:
Let:
u = sin(x)
du = cos(x) dx
I'm really sure it's right.
Don't forget the +C!
Yes you are right, I would have lost 1/2 a mark on a test.
\frac{1}{5} ln(sinx-3)-\frac{1}{5} ln(sinx+2) + C
OR as gb7nash pointed out
<br /> \frac{1}{5} ln(\frac{sinx-3}{sinx+2} + C)<br />
Thanks everyone!
  • · Replies 27 ·
