Indicial Equation for Legendre's Eq. at x=1,-1
  • Thread starter Thread starter sonia akram
sonia akram
:redface:what is the indicial equation associated with regular singularities x=1 and x=-1 of legendre's eq.?
(1-x^2)y''-2xy'+a(a+1)y=0
What have you done to try to find it yourself?
If you write
y= \sum_{n=0}^\infty a_n x^{n+c}[/itex]<br /> what are y&#039; and y&quot;? What do you get when you put those into the equation?<br /> Assuming a_0 is not 0, what is the coefficient of the lowest power of x in that equation?
Don't they have a general formula for indicial equation for the Legendre's equation. I remember they have such a formula for Euler-Cauchy differential equation.
HallsofIvy, that's the series solution for singularity x=0, if we are esprcially working for singularity x=1 or -1 than indicial would be different or not?
Yes, I was using the most common application as an example. If a differential equation has a singularity at x= x0 you would use
y= \sum_{n=0}^\infty a_n (x- x_0)^{n+ c}
thx a lot for ur help!
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
