Induced EMF in loop in magnetic field
A circular loop with a radius of 17 cm is subjected to a magnetic field of 0.7 T, which is increased by a factor of 2.2 over 15 seconds. The initial magnetic flux was calculated as 0.063554 Wb, while the final flux was determined to be 0.2633 Wb. The induced emf was calculated using the formula for change in flux over time, resulting in a value of 0.013316 V. However, this value is very small and may be misinterpreted as zero; it is crucial to ensure all calculations are accurate. The induced emf is positive and acts in the opposite direction to the change in the magnetic field.
GingerBread27
A circular loop of radius 17 cm is located in the plane of the paper inside a homogeneous magnetic field of 0.7 T pointing into the paper. It is connected in series with a resistor of 131 ohm. The magnetic field is now increased at a constant rate by a factor of 2.2 in 15 s. Calculate the magnitude of the induced emf in the loop (in V) during that time.
Ok So first I figured out the area of the loop, and then multiplied this by the B field of .7 T to get the first magnetic flux. I then took the area of the loop, multiplied by (.7+2.2T) to get the second magnetic flux, I then subtracted the first magnetic flux from the second, divided by 15 seconds to get an answer in volts so at least my units are correct, but my answer is wrong!
Area of loop: .090792 m^2
First Magnetic Flux: .063554 Wb
Second Magnetic Flux: .2633 Wb
Voltage=(.2633-.0635)/15 s=.013316 V which is wrong
What am I doing wrong?
Maybe they mean B_{final}=2.2 B_{initial}.
It looks like you have the right approach, but there may be a calculation error in your final step. The correct answer for the induced emf in the loop during the 15 seconds would be 0.013316 V, but this is a very small value and could easily be mistaken for zero or rounded incorrectly. Double check your calculations and make sure you are using the correct values for the magnetic flux and time. Also, keep in mind that the final answer should be positive, as the induced emf will be in the direction opposite to the change in magnetic field.
