Inductance of a coil (negative inductance?)
  • Context: Undergrad
  • Thread starter Thread starter eehsun
    Coil Inductance
The discussion revolves around the i-V relationship for a solenoid, specifically the expression VL = LdiL/dt, and the challenges faced in deriving this relation while adhering to the passive sign convention. Participants explore the implications of self-induced emf and the interpretation of voltage across an inductor.
  • One participant seeks to verify the expression VL = LdiL/dt for a solenoid, questioning why they cannot derive it despite following the passive sign convention.
  • Another participant provides links to external resources that discuss self-induced emf and its negative sign, suggesting that the self-induced emf opposes the original changing current.
  • A later reply emphasizes that the voltage drop across an inductor should be expressed as -L dI/dt, indicating that the initial drawing is correct under certain conditions.
  • One participant acknowledges their understanding of the inductor's behavior under time-varying current but expresses difficulty in demonstrating this through Maxwell's equations.
Participants do not reach a consensus on the derivation of the i-V relationship for the solenoid, and there are differing interpretations regarding the sign of the voltage drop across the inductor.
There are unresolved aspects regarding the application of Maxwell's equations to derive the i-V relationship, and assumptions about the passive sign convention may not be fully clarified.
eehsun
Hi everyone,
I encountered a problem as a part of the solution of which I needed to get the i-V relation across a solenoid to gain some intution in the other parts of the problem, which is the well known expression
VL=LdiL/dt, where V and i are referenced with respect to the passive sign convention.
Nothing tricky here, just basic stuff - however I wanted to quickly verify this before I moved on in the problem. The following is a simple MSpaint sketch that I have just created for illustrative purposes
The rest of the details are in the above picture. The question I had in mind is why I am not able to derive the simple relation VL=LdiL/dt for an inductor (solenoid in this case), even though I referenced everything in line with the passive sign convention?
Thanks!
Any ideas? Something I may be overlooking?
This may help.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/farlaw.html#c2
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/indcur.html#c1
http://faculty.wwu.edu/vawter/PhysicsNet/Topics/Inductance/Solenoid.html
Note in the last link:
This emf is called self-induced since it is the magnetic field of each loop that is creating an emf in the all the other loops including itself.
The negative sign means that the self-induced emf is opposite to the emf creating the original changing current.
I will give this some more thought and follow it up thereafter.
Many thanks for the response!
Note: I know how an inductor should behave under a time-varying excitation current and in this context I know why it makes sense for an inductor to have the particular i-V relation that it does have, V = Ldi/dt. I just have a problem showing this through Maxwell's eqns, but I think I'll hopefully manage to see the error in my approach if I give it some more thought.
The voltage drop across an inductor is -L dI/dt and not L dI/dt.
Your first drawing is O.K. if dI/dt>0 and you consider the initial point is where the current enters the inductor and the output where the current exits the inductor. From that drawing you can easily see the voltage drop is negative (look at the plus and minus signs). That expalins everything.
  • · Replies 16 ·
  • · Replies 21 ·
12K
