Inductance of DC Electromagnet Coil. Help
The discussion centers on calculating the inductance of a DC electromagnet coil with a resistance of 490 ohms and an impedance of 523 ohms, powered by 110 volts at 0.21 amps. Participants clarify that knowing the frequency of the current is essential for accurate calculations, with a common assumption of 60Hz for AC. The formula for inductive reactance (XL = ωL) is emphasized, where ω is derived from the frequency. A calculation method is suggested, using the impedance formula Z^2 = R^2 + (ωL)^2 to solve for inductance. The importance of frequency in determining inductance is reiterated throughout the discussion.
wingsofdesire
I am trying to make a DC electro magnet coil. The Coil is wound up to the core. And works fine. But I'm not being able to find out the inductance of the coil. The Resistance of Coil R20= 490 ohms. Impedence is 523 Ohms. 110v give .21 amps. Please Help.
Is the 110v alternating or direct current? If alternating current, what is its frequency?
modmix said:
what about this:
Given we have just R and L (no C).
They from a triangle: Z^2 = R^2 + L^2.
=> L = sqrt(Z^2 - R^2) = 182 Ohm.
hth
Ulli
That is not correct, you need to know the frequency as has been hinted at. XL = ωL
You say 110volts so I would guess that f = 60Hz (or maybe 50Hz)
The impedance = 110/0.21 = 523Ω. ω Is 2∏60 = 377
So if you do 5232 = 4902 + (ωL)2...see what you get for L.
sure. that's why i deleted my posting - not fast enough...
L measures in H ,-)
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
