Induction by alternating voltage?
  • Thread starter Thread starter infomike
    Induction Voltage
Induction typically involves inducing a current in a conductor through a changing magnetic field from an alternating current in a coil. The discussion raises the question of whether simply alternating the voltage in a coil could also induce current in another conductor, as a changing electric field leads to a changing magnetic field. It is noted that electromagnetic waves do not require an actual current, suggesting a different perspective on induction. The relationship between alternating current and voltage is emphasized, highlighting their interdependence through inductive reactance. The conversation concludes by affirming that voltage and current in AC systems are mutually co-existing phenomena.
infomike
The classic description of induction involves inducing a current in another conductor caused by the changing magnetic field caused by alternating current passing through a coil of wire around a metal core.
Nonetheless, wouldn't simply alternating the voltage in a coil cause induction in another conductor? My reasoning is based on a changing electric field causing a changing magnetic field. Isn't that the way an electromagnetic wave is produced? There is no actual current in an electromagnetic wave.
If I am wrong, what am I missing?
If a coil has alternating current it also has alternating voltage, and vice-versa. With ac and a coil, voltage and current cannot exist independently. Inductive reactance, X is given by 2*pi*f*L. By Ohm's Law, V = I*X, I = V/X, X = V/I. They mutually co-exist.
Claude
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
