Induction - in two parallel wires - affecting voltage?
In a system with two parallel wires, wire 1 carries a constant current, which does not induce a current in wire 2 due to the absence of a changing magnetic field. The current in wire 2 is independent of the steady-state current in wire 1, but it can be influenced by changes in wire 1's current over time. The voltage drop across wire 2 remains unaffected by the magnitude of wire 1's current as long as wire 1's current is constant. Overall, the interactions between the two wires depend on variations in current rather than steady states. The discussion highlights the principles of electromagnetic induction and current behavior in parallel conductors.
Hyo X
Hypothetical, Two parallel wires, wire 1 and wire 2. Trying to understand my system.
A) Wire 1 has a constant current which is being driven by a V and power supply.
Is there a current in wire 2 if the current in Wire 1 is constant?
B) Wires A and B both have current flowing through them. Does the magnitude of the current in 2 depend on the current in 1?
C)Does the voltage drop over wire 2 change depending on the steady state magnitude of current in wire 1?
No. Without an alternating current there is no changing magnetic field and hence no induction.
It does not.
Nope.
First, understand that the dependence of the current in wire 2 could be dependent upon only changes in the current of the wire 1 with a few odd exceptions. The current in wire 2 could be completely independent of that in wire 1 if wire 2 is driven by a constant current source.
In general, this is not a simple question, if say, the resistance of wire 2 is dependent upon an applied magnetic field due to wire 1. I will treat it as a simple.
To answer, I'll assume that wire 2 is a closed loop without a driving voltage or current source unless implied otherwise.
no, the constant current wire 1 generates no changing magnetic field to effect the electric current in wire 2.
no. the current flowing in wire 2 does not depend on the current in wire 1, but how much the current in wire 1 changes over time. The current in wire 2 certainly depends on how much the current in wire 1 changes.
C) Does the voltage drop over wire 2 change depending on the steady state magnitude of current in wire 1?
nope, and it seems Drakkith and I agree on all points.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
