New Forum Member: Induction Problem Solving
  • Thread starter Thread starter kky
    Induction
The discussion revolves around proving the inequality n(1/n) > (n+1)1/(n+1) for all n ≥ 3 using mathematical induction. The member shares their attempt at a solution, starting with the inequality k1/k > (k+1)1/(k+1) and manipulating it algebraically. They explore using binomial expansion but encounter difficulties due to negative terms emerging in their calculations. The member expresses a desire to understand the induction method despite having found an alternative solution. The thread highlights the challenges of applying induction and the complexities involved in the proof process.
kky
just joined the forum
n(1/n) > (n+1)1/(n+1) for all n>=3.
k1/k > (k+1)1/(k+1)
=> k > (k+1)k/(k+1)
=> k+1 > (k+1)k/(k+1) + 1
=> (k+1)1/(k+1) > [(k+1)k/(k+1) + 1]1/(k+1)
I then tried binomial expansion of the term on the right.
leads to
(k+1)1/(k+1) > (k+1)k/(k+1)2 + 1/(k+1)*(k+1)[k/(k+1)][1/(k+1) -1] + (-k)/(2(k+1)2)*(k+1)[k/(k+1)][1/(k+1) - 2]...
But seem to be getting nowhere because of the negative term that appears and will continue to appear in every other term...
Am i on the right path?
apologies if it is too easy.
and btw, I've figured out how to do it without using induction.
but i want to know how to prove it using induction
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
