Inequalities of rational expressions
delsoo
referring to the photo attached, can anyone expalin and give suitable numerical example please? i couldn't understand the notes.
Mathematics news on Phys.org
We know that
\frac{a}{b}=\frac{c}{d}
implies ##ad = cb##. Indeed, to prove it, we multiply both sides of the equation with ##bd##.
The question is now whether \frac{a}{b}<\frac{c}{d}
implies ##ad < cb##.
The answer is no. Indeed, we know that
\frac{-1}{-1} &lt; \frac{2}{1}
but it is not true that ##(-1)\cdot 1 < 2\cdot (-1)##. In fact, it is the reverse inequality that holds.
So the rule
\frac{a}{b}&lt;\frac{c}{d}~\Rightarrow~ad&lt;bc
is only true if ##b,d>0##.
So if you have something to solve like
\frac{x+1}{x+2}&lt; \frac{x}{x-3}
then you cannot solve this by cross-multiplying, that is you cannot say that
(x+1)(x-3)&lt;x(x+2)
because ##x+2## and ##x-3## might be negative. Now, if you know that it's positive, then you can do it, but you don't know this in general.
The way to solve it is to bring both to the same side, so the above is equivalent to
\frac{x}{x-3} - \frac{x+1}{x+2} &gt; 0
and thus
\frac{x(x+2) - (x+1)(x-3)}{(x-3)(x+2)}&gt;0
So we get that a fraction is positive. This can only happen in two situations:
1) Both numerator and denominator are positive. So the above implies
x(x+2)&gt;(x+1)(x-3)~\text{and}~(x-3)(x+2)&gt;0
Solving this yields possible values of ##x## which solve the inequality, but they are not the only solutions:
2) Both numerator and denominator are negative. So we get
x(x+2)&lt;(x+1)(x-3)~\text{and}~(x-3)(x+2)&lt;0
Solving this also yields solutions.
Likes 1 person
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
