MHB Can Inequalities Be Proven? A Solution to a Complex Equation
anemone
MHB
POTW Director
Prove that $\sqrt{x^4+7x^3+x^2+7x}+3\sqrt{3x}\ge10x-x^2$.
Mathematics news on Phys.org
Hint:
Try to think from the perspective of proving the inequality by dividing the domain into two or more intervals.
Solution of other:
Since $\sqrt{x^4+7x^3+x^2+7x}+3\sqrt{3x}\ge10x-x^2$ is true for $x\ge 10$, the proof can continue for the interval $x<10$.
Squaring both sides gives:
$2\cdot 3^{\dfrac{3}{2}}\sqrt{x}\sqrt{x^4+7x^3+x^2+7x}+x^4+7x^3+x^2+34x \ge x^4-20x^3+100x^2$$\dfrac{2\cdot 3^{\dfrac{3}{2}}\sqrt{x}\sqrt{x^4+7x^3+x^2+7x}}{\sqrt{x}}\ge -27x^2+99x-34$
Now we have 2 cases, one of which the RHS is positive, and one of which where it is negative.
Case I:
$0<x<\dfrac{-\sqrt{681}+33}{18}$ or $\dfrac{\sqrt{681}+33}{18}<x<10$ These give RHS a negative, so the relation holds.
Case II:
$\dfrac{-\sqrt{681}+33}{18}<x<\dfrac{\sqrt{681}+33}{18}$
RHS is positive in this interval, so squaring both sides again we have
$\left(\dfrac{2\cdot 3^{\dfrac{3}{2}}\sqrt{x}\sqrt{x^4+7x^3+x^2+7x}}{\sqrt{x}}\right) ^2 \ge (-27x^2+99x-34)^2$
$-729x^4+5454x^3-10881x^2+6840x-400\ge 0$
$-(3x-4)^2(81x^2-390x+25) \ge 0$ and this inequality holds true in the interval $\dfrac{-\sqrt{681}+33}{18}<x<\dfrac{\sqrt{681}+33}{18}$ and therefore, we can conclude that $\sqrt{x^4+7x^3+x^2+7x}+3\sqrt{3x}\ge10x-x^2$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
