Calculating Inertia Tensor of Hollow Cone
esradw
I need to find the inertia tensor for a uniform thin hollow cone,spinning about its ponted end.
When the cone is solid then everything goes very smoothly by using cylindrical polar coordinates. But how should I find if it is a hollow cone. To be able to write the density of the cone I have to use the area of the cone and when I want to find ( Izz ) I need to write the dm=density.dv but how am I going to write the dA in cylindrical polar coordinates . If I could find the Izz then I could jump into finding of Iyy and Ixx and the products of inertia must be 0 because of the symmetry.
please help
thanks
You can easily find the result for a spinning ring of a certain radius. Try breaking the hollow cone up into a series of rings and integrating.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
