Infinite geometric series problem
MillerGenuine
\sum_{n=1}^\infty \frac{(-3)^{n-1}}{4^n}
\sum_{n=1}^\infty \frac{(-3)^n-1}{4^n}
\frac{1}{4}\sum_{n=1}^\infty \frac(-{3}{4})^{n-1}
Can some one please explain how they got from the first step to the 2nd. How do you pull out a 1/4 and how does the "n" on the 4 dissapear?
Thanks
Can you fix your third summation? It's all fouled up.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
