Infinite limits using L'Hospital's Rule
  • Thread starter Thread starter Asphyxiated
    Infinite Limits
Asphyxiated
\lim_{y \to \infty} \frac {\sqrt{y+1}+\sqrt{y-1}}{y}
By L'Hospital's Rule:
\lim_{y \to \infty} \frac {\sqrt{y+1}+\sqrt{y-1}}{y} = \lim_{y \to \infty} \frac {\frac{1}{2}(y+1)^{-1/2}+\frac{1}{2}(y-1)^{-1/2}}{1}
which is just this:
\lim_{y \to \infty} \frac{1}{2}(y+1)^{-1/2}+\frac{1}{2}(y-1)^{-1/2}
and the answer is suppose to be 0, is this because you are basically taking the reciprocal of infinity which is infinitely or arbitrarily close to 0?
when you apply the limit, you should get 1/infinity + 1/infinity, which is 0 + 0 = 0.
A small number over a much larger number goes to 0.
Edit: Instead of using L'Hopital's Rule, you could just say that the power of y in the denominator is larger than the power of y in the numerator, so since you're taking the limit as y approaches infinity, you could say the limit is zero. Do you see why?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
