Infinite Series Comparison Test
Gear300
I read a proof for showing that the harmonic series is a diverging one. This particular one used a comparison test:
1 + 1/2 + 1/3 + 1/4 + 1/5 + 1/6 + 1/7 + 1/8 + 1/9 + ... + 1/16 + ...
1/2 + 1/2 + 1/4 + 1/4 + 1/8 + 1/8 + 1/8 + 1/8 + 1/16 +... + 1/16 + ...
Each term in the second series is < or = to the corresponding one in the first...and the proof is that grouping terms in the second series gives 1/2 + 1/2 + 1/2 + 1/2 + ..., which diverges. The problem I'm having here is accepting the validity of grouping the terms to produce a sum of continuous 1/2's...there was also the case, in which:
(1) 1/2 + 1/5 + 1/8 + 1/11 + ... is less than
(2) 1 + 1/2 + 1/4 + 1/8 + ... and because (2) converges as a geometric series with r < 1, by the comparison test, series (1) converges. However:
(3) 1/3 + 1/6 + 1/9 + 1/12 + ...can be written as 1/3(1 + 1/2 + 1/3 + 1/4 + ...), which diverges (as a harmonic series). (3) is less than (1) term by term and should converge by the comparison test, but it doesn't according to observation (I'm trying to find the error in the argument just stated since it was stated that there is one). If grouping were valid, then wouldn't there be a noticeable flexibility in the validity of the comparison test?
Mathematics news on Phys.org
You are comparing (1) and (2), asserting terms of (1) are less than terms of (2). This is not true, even for the next term. For (1) the next term is 1/14 while for (2) it is 1/16. As you continue the terms of (2) get a lot smaller than the terms of (1).
I hope you were not being facetious.
Heheh, apparently I wasn't. I guess I didn't see all sides of the argument.
Still...is grouping like that valid?...it doesn't work on a series such as:
1 + (-1) + 1 + (-1) + ... or is that only because this one alternates in sign?
Rearrangement of terms in a series should only be attempted if
(1) all terms are nonnegative, or
(2) the series is absolutely convergent.
As discussed in a different thread, the Riemann Series Theorem indicates rearrangement does not guarantee equality in other cases.
--Elucidus
EDIT: (1) can be expanded to include "eventually nonnegative."
--Elucidus
Interesting...Thanks for the replies.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
