Infinite Square Well Frequency of Oscillation
Blitzmeister
Consider a particle in an infinite square well potential that has the initial wave-function:
Ψ(x,0) = (1/√2) [Ψ_1(x) + Ψ_2(x)]
where Ψ_1(x) and Ψ_2(x) are the ground and first excited state wavefunctions. We notice that <x> oscillates in time. FIND the frequency of oscillation
So,
<x> = expected value integral over 0 to L
Ψ_1(x) = √(2/L) sin(πx/L)e^(-iE/ћt)
Ψ_2(x) = √(2/L) sin(2πx/L)e^(-iE/ћt)
I solved:
<x> = [(1/2)-(16/(9π^2))]L
(Not only did I do this by hand but I also checked it against mathematica so this is definitely not wrong)
Real question is, WHAT is the frequency of oscillation actually? I have NO idea what the question is asking.
What happened to the exponential time factors. Hint: E is not the same in Ψ_1 and Ψ_2.
Ah so they are different. Okay so what I did, which I guess is wrong was cancel the two exponential time factors since they were e^(-iEt/hbar) and e^(-iEt/hbar)
In that case then still, what exactly is the oscillating frequency? omega?
Right, the time factors are different and so they won't cancel. You should recalculate <x>. You will get a time dependence from which you can deduce the oscillation frequency.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
