Infinite wavelength resonant antennas
An infinite wavelength antenna refers to an antenna designed to operate at a frequency where its reactive impedance is minimized, optimizing efficiency. Resonant antennas function best at a specific frequency, allowing for better matching with transmitters and reducing off-frequency signal interference. Various broadband antennas, such as cone and discone types, can cover extensive bandwidths, making them suitable for applications requiring wide operational ranges. The directional properties of antennas can be enhanced through the use of arrays with controlled phase shifts, a technique known as beam forming. Understanding these concepts is essential for effective antenna design and performance.
Stanley514
Could somebody explain what does mean "infinite wavelength antenna" and what advantages does it have? What is resonant antenna and advantages?
http://webcache.googleusercontent.com/search?q=cache:fHdO6P-aoIIJ:dspace.nitrkl.ac.in:8080/dspace/bitstream/2080/1320/1/MMET.pdf+&cd=4&hl=en&ct=clnk&gl=ca
Sorry but your link doesn't work. Stanley.
Many (if not most) antennae operate at a frequency at which the reactive part of their impedance is a lot lower than the resistive part. This happens when the Inductive impedance is nearly equal and opposite to the Capacitative impedance and that is at a resonance. The antenna can then be 'matched' to the transmitter and feeder cable and the efficiency can be optimised.
Don't take this as all you need to know about antennae. They are fiendishly hard devices to understand - but it's a start.
A tuned antenna is designed as a “resonant circuit”. It operates best at one frequency. Tuning tends to reject off frequency signals while favouring the wanted signal frequency.
There are many different broadband antennas that cover a significant bandwidth, often a factor of ten. Some examples are the cone, discone and loop or patch antennas that are smaller than about 1/10 wavelength. These are used where a wide band of operation is required.
The directional characteristic of small elements is a simple dipole. By using an array of several small wideband elements and inserting a controlled time delay or phase shift in their feed lines, the directional characteristics of the array can be controlled. That is called “beam forming” or “aperture synthesis”.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
