Inflection points theorem for quadratic functions.
The discussion revolves around the properties of quadratic functions, particularly focusing on the relationship between inflection points, critical points, and the quadratic formula. Participants explore the mathematical expressions involved and their implications for understanding the behavior of quadratic equations.
  • One participant suggests that an inflection point occurs when the slope of a function equals zero, relating this to the derivative of a quadratic function.
  • Another participant corrects this by stating that an inflection point is where the second derivative is zero, not the first, and discusses the nature of critical points.
  • There is a discussion about the similarity between the expressions for the vertex of a parabola and the quadratic formula, noting the common terms -b and 1/2a.
  • A participant elaborates on completing the square to derive the quadratic formula, indicating that this process reveals similar results to those discussed.
  • Another participant points out that the roots of the quadratic equation are equidistant from the vertex, which is the minimum or maximum value of the function.
Participants express differing views on the definitions of inflection points and critical points, indicating a lack of consensus on these concepts. The relationship between the quadratic formula and the expressions discussed remains exploratory and unresolved.
There are limitations in the discussion regarding the precise definitions of inflection points and critical points, as well as the assumptions made in the derivations presented.
zketrouble
Hey all,
I was bored as heck with my internet down and started scribbling some random math stuff. I'm sure what I've come up with is old news to most but I found some interesting properties in the following proof and I'm curious what my fellow physicsforums users can come up with to see what the causes are for the relationships between my proof and the age-old quadratic formula.
An inflection point occurs when the slope of a function equals zero. So for quadratic equations (and all other equations) of the form f'(x) = ax^2 + bx + c, f'(x) = 0 at inflection points.
d/dx ax^2 + bx + c = 0
2ax + b = 0
2ax = -b
x = -b/(2a).
It's interesting (though not at all surprising), that the terms in this are similar to what is seen in the quadratic formula -b +/- [(b^2 - 4ac)^1/2]/2a
Both expression have a -b and both have a 1/2a. Its not all that surprising that the two expressions would be related, but where is the direct link between the quadratic formula and the expression I came up with?
zketrouble said:
Hey all,
An inflection point occurs when the slope of a function equals zero. So for quadratic equations (and all other equations) of the form f(x) = ax^2 + bx + c, f'(x) = 0 at inflection points.
This is not true, although it might be a typo. A critical point for a function is where the derivative is 0 (or does not exist). An inflection point is where the derivative changes from increasing to decreasing and so occurs where the second derivative is 0 (or does not exist).
2ax + b = 0
2ax = -b
x = -b/(2a).
Yes, for a parabola, the derivative is 0 only at the vertex- and you can find that by completing the square.
[tex]ax^2+ bx+ c= a(x^2+ (b/a)x+ c/a)= a(x^2+ (b/a)x+ (b^2/4a^2)- b^2/4a^2+ c/a)[/tex]
[tex]= a((x+ b/2a)^2+ c/a- b^2/4a^2)= a((x+ b/2a)^2- \frac{b^2- 4ac}{4a^2}[/tex]
Now, if a> 0, that is the number [itex](b^2- 4ac)/(4a^2)[/itex] plus something that is positive unless [itex]x+ b/2a= 0[/itex] and so has the value [itex]-(b^2- 4ac)/(4a^2)[/itex] as its minimum value at [itex]x= -b/2a[/itex]. If a< 0, it's turned over and that point is a maximum.
Of course, the quadratic formula comes from applying "completing the square" to [itex]ax^2+ bx+ c= 0[/itex] so you get similar results.
hey zketrouble! :smile:
(have a ± and try using the X2 icon just above the Reply box :wink:)
zketrouble said:
… Both expression have a -b and both have a 1/2a. Its not all that surprising that the two expressions would be related, but where is the direct link between the quadratic formula and the expression I came up with?
ax2 + bx + c = 0
-> a[(x + b/2a)2 + (4ac - b2)/4a2] = 0 :wink:
Thanks for the correction, I always get the two mixed up :p
The roots of the quadratic equation are found at equal distance of the point where minimum/maximum value is obtained for ax^2 + bx +c meaning.
As you well computed for x = -b/2a you get the minimum/maximum value of ax^ + bx + c. This point is in the middle of the two roots therefore you have to substract a value D to find the first root and to add a value D to find the second root.
x1 = -b/2a - D
x2 = -b/2a + D
Thanks everybody! I was almost tearing my hair out in wondering the connection.
  • · Replies 36 ·
11K
  • · Replies 27 ·
  • · Replies 19 ·
