Information of secondary neutron source in French PWR
The discussion focuses on the specifics of secondary neutron sources in French 1300MWe and N4 pressurized water reactors (PWRs). Participants seek detailed information regarding the total mass of antimony-beryllium (Sb-Be) in the reactor core, the thickness of Sb-Be cladding with stainless steel, and related configurations. The scope includes technical specifications and design comparisons with other reactor types.
  • One participant notes a lack of information available in English and suggests searching in French for more details.
  • Another participant references an article that provides data on the density of Sb and Be, mentioning that the design pertains to a 16x16 OP-1400 fuel design, which is similar to the CE System 80.
  • Details about the configuration of source rods are provided, including that typically there are 4 source rods per assembly in two or four assemblies.
  • For a typical 17x17 core, a diagram of an Sb-Be secondary source is mentioned, along with specific measurements for the length of Sb-Be and the dimensions of the stainless steel cladding.
  • One participant expresses gratitude for the information shared and highlights the configuration of Westinghouse-type secondary sources, noting that the most universal configuration contains 4 source rods.
  • Another participant discusses the Westinghouse AP-1000 design, mentioning that both primary and secondary source rods use the same cladding material and contain antimony-beryllium pellets, but points out a conflict in reported lengths of the absorber.
  • There is a suggestion that more Sb-Be rods with shorter active lengths are used in the EPR reactor core, but not longer source rods.
  • Links to various documents are provided for further reference, but the availability of specific information on the French 1300MW and N4 units remains limited.
Participants express a consensus on the general configuration of source rods but do not reach agreement on specific details regarding the French 1300MW and N4 units. Multiple competing views and uncertainties about the exact specifications and configurations remain unresolved.
Some limitations include the potential dependence on specific reactor designs and the lack of comprehensive data on the French PWRs in English. There are also unresolved discrepancies in reported measurements of the absorber lengths.
Pengtaofu
The specific information of secondary neutron source in French 1300MWe and N4 PWRs are needed, e.g.the total mass of Sb-Be in core and the thickness of Sb-Be cladding with stainless steel, but unfornately I couldn't find any useful information in google in English. I guess some informatio could be found in google in Fench,Could anyone help me to search information? Thank you very much for any help.
The following article contains some data, e.g., density of Sb and Be, and SS, but unfortunately the design is for a 16x16 OP-1400 fuel design (similar to CE System 80).
http://www.sciencedirect.com/science/article/pii/S1738573316300572
Typically there are 4 source rods per assembly in two assemblies, or sometimes four assemblies.
For a typical 17x17 core, with a core height of 3.66 m, there is a diagram of an Sb-Be secondary source here
http://www.pnl.gov/main/publications/external/technical_reports/PNNL-19151.pdf.
The length of Sb-Be is 88 inches (223.5 cm). The stainless steel (SS 304 or 316) cladding outer diameter is approximately 0.968 cm, and the wall thickness is approximately 0.057 cm. It's possible that a longer Sb-Be would be used for the 4.27 m core, e.g., 260 cm.
Thank you very much for providing so much useful information and document.
There are some clues about configuration of Westinghouse-type secondary sources assembly and the most univesal configuration contains 4 source rod, which could been foungd at Page 25/56 in document Integrity of Neutron-Absorbing Components of LWR Fuel Systems.pdf http://www.osti.gov/scitech/servlets/purl/5980553/.
However, there are seldom information of secondary source in French 1300MW and N4 unit in web. It may get some clues if one seach in French.
As I know, more Sb-Be rods with shorter actived length are used for about 4.2m reactor core in EPR, but not more longer source rod.
The description of the Westinghouse AP-1000 (~4.2 m core) has the following as some information on the secondary source rods.
http://www.nrc.gov/docs/ML1117/ML11171A444.pdf
The primary and secondary source rods both use the same cladding material as the absorber rods.
The secondary source rods contain antimony-beryllium pellets stacked to a height of
approximately 88 inches [223.5 cm]. The primary source rods contain capsules of californium (plutonium beryllium
possible alternate) source material and alumina spacers to position the source material
within the cladding. The rods in each assembly are fastened at the top end to a hold-down
assembly.
The other structural members, except for the springs, are constructed of Type 304 stainless steel.
The springs exposed to the reactor coolant are nickel-chromium-iron Alloy 718.See Figure 4.2-15 Secondary Source Assembly
There is a conflict between this figure Ref: 97.0 absorber length [246.4 cm] and the 88 inches [223.5 cm] in the text. The figure is probably correct, and that would likely apply to the 4.2 m cores of the CPY and N4/P4 plants.
There may be some information here
http://www.irsn.fr/fr/documents/ra2010/irsn_dsu-217_tritium-sources-production.pdf
23K
11K
  • · Replies 23 ·
