Infrared Wave Length & Working Range
7 replies · 2K views
kowshikd7
i want to know about wave length of infarade wave and working range
Infrared(I think that's what you mean by infarade) waves encompass the region of the electromagnetic spectrum right before light, commonly considered as heat radiation. As it is present right before light, it has a frequency that is a bit lower, and a wavelength that is higher as a result of the equation given in a post above. Due to the lower frequency, it also has less energy, also given in an equation in a post above.
Or, in less nerdy terms, infrared is the segment before light, with lower energy/frequency.
What do you mean by "working range"?
I want to know about the working range of Infrared receiver and transmitter and also if there is any type of IR transmitter just like as RFID Passive tag
is the wavelength of light the frequency that it sends out photons?
what? makes no sense.
Infrared is the part of the EM spectrum between the upper end of visible and microwaves.
Roughly 750 nm to about 1 mm. I am sure there is some disagreement on the upper boundary, but long wavelength IR and microwaves have a lot in common.
Typically, short-wave infrared (SWIR) is from 0.7 um to 1.1 um, the part of the spectrum we can't see but that Si detectors can still respond to. Mid-wave (MWIR) is about 3-5 um and long-wave (LWIR) is 8-12 um: both bands are set by absorbance bands of water, and the MWIR and LWIR bands are within 'transmission windows'. Going out further, for example in FTIR measurements, the far infrared can go out to about 20um or more.
