Initial Amplitude and the Release Point
The discussion centers on a pendulum problem involving initial amplitude and its reduction over time due to friction. The initial amplitude is confirmed to be the release point, particularly when the initial velocity is zero. The user calculated the damping coefficient (beta) to be 3.28x10^-4. Clarification was sought on whether the initial amplitude is indeed the release point, which was affirmed. The conclusion is that the calculations are correct based on the provided parameters.
moo5003
Question:
"A pendulum with a length of 2.82m is released from an initial angle of 17.5 degrees. After 1100s, its amplitude has been reduced by friction to 5.30 degrees. What is the value of b/2m?"
Word Done:
A = A(initial)e^(-betaT)
Basically I have done the problem on the basis that A(initial) is equal to 17.5 degrees. I just wanted to make sure that the initial amplitude is actually the release point? Or is there a way to find it.
For anyone that would like to check my answer was:
Beta = 3.28x10^-4
As long as the initial velocity is 0, the release point is the initial amplitude.
Thank you for your quick response ^_^, that means I should have the right answer as is.
