What is the relationship between f-1(f(A0)) and A0 in terms of injectivity?
tomboi03
I'm not sure how i would go about this problem...
Let f: A-> B
(which i know means... f is a function from A to B which also means... that A is the domain and B is the range or image)
Let A0\subsetA and B0\subsetB
a. show that A0\subsetf-1(f(A0)) and the equality hold if f is injective.
b. show that f-1(f(B0)) and B0 and the equality hold if f is surjective
thanks
It follows from the definitions.
Given x in A0, show that it is in f-1(f(A0)). What is f-1(f(A0))? It's the set of all things that map into f(A0). Surely, x is in that set.
To show equality when f is injective, show the reverse inclusion; i.e. show that f-1(f(A0)) is contained in A0. So let x be in f-1(f(A0)), which means that f(x) is an element of f(A0). That means that f(x) = f(x') for some x' in A0; by injectivity, x = x', so x is in A0.
The second part is similar. You really should make a serious attempt at these problems (this and the other two you posted here); they're quite easy. Just make sure you know what the definitions are.One more thing: f: A -> B does not mean that B is the image of f. It's ok to use words like codomain or target for B, but it's not the image unless f is surjective. Remember, the image of f is the set f(A) = {f(x) | x in A}, which is always a subset of B, but not necessarily all of B. The range of f may refer to either the entire set B or the image of f; it depends on the author. (I personally highly prefer range to mean image, but I typically avoid that term anyway.)
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
