Instantaneous Speed Homework - Caltech: Mechanical Universe
  • Thread starter Thread starter AntonJD
    Speed
The discussion revolves around confusion regarding the formulas for instantaneous speed presented in the Caltech video "The Mechanical Universe." The formula V(t) = 2ct is intended to describe velocity as a function of time, particularly in scenarios like a roller coaster in free fall, where c represents the distance fallen in the first second. In contrast, the formula v = vi + gt describes the vertical speed of a freely falling object, with vi as the initial velocity and g as the acceleration due to gravity. Clarification suggests that V(t) could be interpreted as V(t) = 2(c/t), indicating that the instantaneous velocity at the end of a time interval is double the average velocity. Overall, the key issue is reconciling these formulas to accurately express instantaneous speed.
AntonJD
I have just been watching Caltech: The Mechanical Universe and I'm a little bit puzzled by the instantaneous speed section, i understand the concept, if you try d/t you're deviding by zero at a fixed point so you can instead calculate ahead and reduce down to find the answer but the formula is what is puzzling me. The video shows V(t) = 2ct and elsewhere I'm being told it's v = vi + gt. Can someone shed some light on this or point me in the right direction.
V(t) = 2ct
v = vi + gt
N/A
What situation is that formula meant to describe?
That formula describes the vertical speed of a freely falling object, such as a ball tossed into the air. vi is the initial velocity; g is the acceleration due to gravity.
The formula was used to describe a roller coaster in free fall from a stopped position, and the formula was described as V(t) being velocity as a function of time, C as the distance which a body falls in the first second (which was given as 16ft or 5M). I've gotten myself so confused over this now that I've been trying to figure it out for about 2 hours, the most frustrating part is that I'm sure i understand the concept of it, just making sure i have the correct formula and expressing it as a formula is proving difficult.
Perhaps the formula was V(t) = 2(c/t). That makes sense. c/t, which is distance traveled over time, gives the average velocity during that time. But the instantaneous velocity at the end of that time interval is twice that. (Note that it starts from rest.)
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
