Integral Fast Reactor: Why Did Funding Stop?
  • Thread starter Thread starter catseye747
    Integral Reactor
158 replies · 45K views
When DOE first started funding the hot fusion program, did they require MIT before one dime flowed to prove that even IF they achieved hot fusion that the engineering considerations had a realistic chance of converting extremely energetic particles into electricity at 10cents/kWh, or was that just left up to the paeons, the engineers, to figure out? Would you steer me to a website from circa 1975 literature where MIT scientists connected the dots i.e. going from the plasma to electricity at 10 cents/kWh? There is no business model; utilities don't want expensive, complicated equipment that requires a Phd in physics to understand.
Light water reactors are simple; Mother Nature even built one in Oklo 1.7 billion years ago just to show you that you don't need physicists to build fission plants. Yet proponents of hot fusion will tell you, "We went from creating fission to commercial application in about 10 years. This should be possible with hot fusion reactors." Right!
As for the economics of plasma fusion: It requires incredibly complicated (does Murphy's law ring a bell?) unbelievably expensive equipment whose fuel right now costs as much as burning one carat diamonds in the reactor, and additional cooling towers even if Q=10, compared to either base-load coal or light-water reactors. Compared to that, we have simple, rapidly improving technology with free or cheap fuel and no cooling towers i.e. wind, solar, geothermal, and cellulose bio fuel. And, of course, the IFR has much cheaper fuel, is less complicated, has hundreds of years of reactor time under its belt, etc.
When were the hot fusion people going to tell America that there are small, but measurable amounts of the radioactive gas tritium released into the air as part of the cost of doing business? When were they going to tell Americans if tritium amounting to as little as a pound were stolen (start up amounts for a hot fusion reactor are about 10-12 pounds), it could be used to could convert a suitcase bomb into a bomb 1000 times the size of Nagasaki. Worried about suitcase bombs? You can buy tritium on line where you will also find a highly detailed schematic of a fission-fusion-fission bomb.
When were they going to tell Americans that the waste products of hot fusion are shorter-lived but more deadly than the waste from existing nuclear plants? This is a public relations time bomb just waiting to go off.
Now for the farcical Inertial Confinement Fusion program at Lawrence Livermore National Laboratory. On Charlie Gibson, we have this real nifty cartoon showing the ICF plant firing every second. Let me get this straight---they are going to go from 100,000,000 degrees C to -260 degrees C (the temperature of a deuterium/tritium sand grain) in less than one second. Sounds reasonable doesn't it?
Of course the amount of energy seems pretty trivial to create enough to drive a base load plant, probably less than 300mW with just one gallon of gasoline/sec., the amount appearing from their trade literature. One minor detail---one pound of gasoline has the explosive equivalent of 15 pounds of dynamite. In other words we have the equivalent of 100 pounds of dynamite going off in the chamber every second!
Here are the steps: 1)Intake, 2)Compression, 3)Ignition, 4)Exhaust. Doesn't this sound like an internal combustion engine? Is this how we drive ICF reactors? Perhaps due to the wildly varying yield of each explosion, we could go with a flywheel, just like on a John Deere tractor. It would have to weigh at least 1000 tons and turn at a very rapid rate.
How long will it take to completely destroy the reactor vessel after thousands of explosions every day, not to mention the effect of the high energy neutrons on the reactor itself?
The deuterium/tritium particle entering the chamber will be about the size of a grain of sand. This requires Star Wars in a bottle i.e. we must be able to track a moving target and fire on it with tolerances in the neighborhood of trillionth of a second with over 100 lasers simultaneously. Sounds easy, doesn't it?
Now for the clincher. How do you isolate the lasers from a 100 pound stick of dynamite going off a few feet away? Suppose the laser zigs, when it should zag? How do you achieve ignition when the implosion front is all over the map due to the vibrating lasers. Bottom line, the reactors are going to have to cool off probably for over a minute, before the next sand grain of deuterium/tritium enters the champber; also, we must allow the lasers to calm down. Instead of one chamber, we might need as many as 60 chambers to get the amount of electricity ICF devotees believe is possible. Be prepared to pay $10/kWh for electricity generated by ICF.
As for fusion being the technology of the 22nd Century. Great! We've had pork for physicists for 35 years; now we can look forward to pork for physicists for another 100 years! Ever wonder where Dick Cheney learned how to funnel multi-billion no-bid contracts to Halliburton? He learned it from DOE and their multi-million dollar no-bid contracts to their hot fusion physicist buddies at MIT.
\QUOTE=Captainjf;1925304]I am in debate and i was instructed by my teacher to find negative evidence on the IFR reactor. is there anything wrong with the reactor that stands out a lot?[/QUOTE]
sloughter,
Light water reactors are NOT simple. Mother Nature had an advantage back a few million years ago -
the enrichment of natural uranium was higher.
Additionally, designing the reactor to be critical is not the only concern - the reactor had to be
controllable, had to be able to withstand accidents...a number of things that Mother Nature didn't
need to take into account.
Dr. Gregory Greenman
Physicist
sloughter,
If I could comment - I'd tell you how much those detailed schematics are worth. You can get schematics
of cars on the Internet - but do they tell you the spring constants of the springs in the car's suspension, or
how the piston rings were heat treated? Additionally, the DOE has never released a schematic of a true
nuclear weapon design - so the only things you see on the Internet are GUESSES at what the design is by
people who have never seen the real designs.
No one is going to simply turn the rumored "suitcase" nuke into a thermonuclear bomb. The design o
nuclear weapons is MUCH, MUCH, more complex than you are imagining. The US nuclear design labs
have always had the largest and most powerful computers available, as well as first rate experimental
facilities. It evidently takes a lot more than just some Internet schematics to engineer a nuclear weapon.
Even if tritium were released [ which is not necessary - I don't see where you get that assumption ];
Mother Nature is already producing tritium in the upper atmosphere to rain down on you - and anything
that Man could add would be an INSIGNIFICANT SMATTERING compared to what Mother Nature
is already exposing you to.
Physicist
sloughter,
That's what bombs do - why do you have a problem with it? You don't think it can happen?
Actually, the idea is several times a second - but why is that a problem?
Why do you think there would be wildly varying explosive yields?
We have chemical explosives where the yield of each stick is well controlled from stick to stick -
otherwise people who use explosives could gauge how much explosive to use for their application.
The vessel isn't going to be destroyed by the micro-explosions. The effect of high energy neutrons
on the reactor vessel is a known quantity and the system is designed to deal with it. Unlike an LWR;
the vessel doesn't confine a large pressure of working fluid. So what is the problem?
Because the laser are NOT a few feet away. At NIF, the lasers are in an adjacent building more than
100 feet away.
Because the lasers are NOT vibrating - they are a good distance away and don't feel the effects
of micro-explosions.
Why do you need to let the lasers "calm down"?
You can run a continuous laser and use a Pockels cell to divert the continuous laser to the target
chamber for the brief period of time to hit the target. The laser's won't need a cool down - they are
running continuously in steady state.
MIT and DOE contract similar to the way most science is done - for instance between a university and
the National Institute of Health, or the National Science Foundation. MIT or other university makes
proposals to a funding agency like DOE, NIH, NSF... and that agency looks at the multitude of
proposals they get and decide which to fund. They make the judgment as to what looks like a good
idea and what doesn't.
The process is nothing like Cheney funding Halliburton at all.
Physicist
vanesch said:
Time-averaged too ?
The LIFE design is for a repetition rate of 20 Hz.
I don't know. Cook water with it ? A layer of a few meters of water would surely stop them and get most of their energy, no ? (and even produce deuterium) I have to say that I'm not terribly well versed in the technicalities of fusion.
And if you have that much water - a few meters thick - at what power level do you have to
operate the fusion reactor so that you get enough energy to boil that much water?
Hot water doesn't do much for generating electricity - perhaps if your goal was for residential
heating for the city, hot water is OK - but you need to turn the water to steam in order to get
something to turn a turbine with.
Physicist
Physicist
Lower boiling point fluids? And the power required to boil the water is dependent upon the water volume _and_ the heat flux out of the system.
This is why this is *research*. Explore nature, explore technologies, see what can be done, and what not. This is not *devellopment*. It is *research*. There is no planned outcome of research. There is a goal that is aimed for, and that is to FIND OUT what can be done and what not, and how. It is money for knowledge, not for working things.
And this is why this is in no competition with *devellopment* like the IFR. With the IFR, there is no question to be answered "can this be done" but rather, "how do we do this best ?" knowing it CAN be done.
It would be silly not to ask the question "can fusion be done? ", no ? It will take probably a century to answer that question. It's a scientific/technological question.
Yes, so that's the time that is available to find out whether fusion is feasible.
The "complicated technology" argument is relative. If you would have proposed a cellular telephone network in the beginning of the 20th century, one would have told you that this was technologically too complicated.
The problem with selling a technology with too rosey arguments is always that it hits you back in the face at some time.
The main potential advantages of fusion over fission are:
- no LARGE amounts of highly radioactive material present (the complete dispersion of the contents of a fusion reactor in the environment - assuming complete failure of all forms of containment - is way way less severe than the same with a fission plant)
- no need to keep cooling when the reaction stops
- large provision of combustible material
- no long-term waste apart from activated structures
And research has to determine whether it is going to be possible to do so.
It is ironic that Kennedy's brain cancer treatment includes radiation...
Erh, if it is going to be a power plant that delivers power, I'd say that one would expect a few GW of time-averaged continuous thermal power, no ? Otherwise it is not a power source worth the attention, I'd say. One would expect a thermal power flux to be at least comparable to a good old PWR. And boil water in the same way ? So a pressurized water mantle from which to make steam at 300 C or the like ? You can of course also have a liquid metal mantle, but the problem is that you need to have enough scattering cross section with neutrons in order to absorb their energy. Gasses will be too tenuous I guess.
vanesch,
I think you will find that the heat fluxes in a tokamak are considerably LOWER than what one would
find in a PWR. A few Gw(t) PWR core is MUCH more compact than a few Gw(t) tokamak. NONE
of the conceptual designs for tokamak "balance of plant" that I've seen consider jacketing the tokamak
with water. Water really doesn't have the properties that you want for your neutron energy to heat
transfer medium. A denser material would certainly be much more desireable.
It's usually jacketed with a molten salt or "Flibe" (LiF-BeF2) as opposed to water.
http://www.osti.gov/bridge/purl.cov...815705858A99?purl=/752080-IbRXGs/webviewable/
Heat fluxes in a tokamak is considerably below what one would find in a PWR; after all the plasma density
that can be magnetically confined in a tokamak are quite low - most would call such densities a "near vacuum".
When you have very low densities - you aren't going to be able to support very high heat fluxes vis-a-vis a
denser solid material.
Physicist
RobertW,
What is really ironic is the MIT has been researching a technique call BNCT -
Boron Neutron Capture Therapy that is intended to treat gliobastoma multiforme
which is exactly the brain cancer that Kennedy has:
http://web.mit.edu/nrl/www/bnct/
http://web.mit.edu/nrl/www/bnct/info/description/description.html
Kennedy has been fighting MIT on this - and now it turns out he was fighting the
very research that might have saved his life if it had progressed further.
Physicist
As I said, I'm not well-versed in this problem. However I would guess that this salt is essentially there to try to get every neutron captured by lithium, in order to get the balance about right ? After all, you use up one tritium nucleus for one fusion reaction and you get out exactly one neutron. On Li-6 you get your tritium back, but you use up the neutron ; on Li-7 you produce a triton and you get a new neutron, which is what can make your balance work out. I guess that's the principal reason for this blanket. I don't see why one couldn't heat water with neutrons if the only goal would be to get the heat out and use it.
Proliferation advantage/disadvantage? Oversight or discounted?
mheslep,
Actually, it's quite the opposite!
Nuclear fusion because it produces high-energy fast neutrons is good for destroying
weapons grade materials - and doesn't produce weapons usable material. In this
respect it is like the LLNL fission-fusion hybrid system, LIFE:
https://lasers.llnl.gov/missions/energy_for_the_future/life/
By burning nuclear waste for its fuel, LIFE has the added benefit of dramatically shrinking the planet's
stockpile of spent nuclear fuel and other materials that lend themselves to nuclear proliferation.
https://lasers.llnl.gov/missions/energy_for_the_future/life/benefits_challenges.php
LIFE is proliferation resistant. Proliferation risk, the chance that fuel destined for a nuclear power plant
could be diverted for weapons purposes, is virtually eliminated with fuel for a LIFE engine.
In that sense, it is like the IFR - which can also destroy weapons material and does
not make weapons usable material.
Of course, the whole proliferation aspect is overblown anyhow. Commercial nuclear reactors
really aren't a very good way of producing weapons material. In fact, the number of nations
that have nuclear weapons that obtained their weapons material by co-opting a commercial
nuclear power program is precisely ZERO. EVERY nation that has nuclear weapons got its
nuclear material by building special purpose facilities, like a production reactor.
Physicist
This is true. So I essentially agree with you. But if you want to nitpick, any source of fast neutrons can be abused in principle to make plutonium from depleted uranium, so a fusion reactor, or a fast reactor, or a fusion-driven sub-critical fast reactor (LIFE) ... all of them can, in principle (I don't say it is practical) be used as a "production reactor". Now, as you say, if you have enough technology in house to do so, then it is way easier to build a standard production reactor.
vanesch,
Actually you DO NOT WANT fast neutrons on depleted Uranium for making Plutonium - you want
THERMAL neutrons. The reaction you want to happen is a capture reaction in order to transmute
U-238 to Pu-239. Thermal neutrons can do that quite well.
If you have fast neutrons; like from a fast reactor or thermonuclear system; then you are above the
FISSION threshold for U-238. That's NOT what you want to do.
Production reactors are moderated thermal reactors. For example, the production reactors at
Hanford were thermal reactors moderated by graphite, and the production reactors at
Savannah River were heavy water moderated thermal reactors.
The fast neutron systems like the IFR, thermonuclear systems, or LIFE are Plutonium BURNERS!
[The IFR can also make Plutonium - but NOT weapons usable Plutonium. ]
Physicist
I thought that the problem with using thermal neutrons to produce plutonium (although, as you say, that is the standard way of producing weapons-grade plutonium) was that you need to remove the uranium when there is a low amount of bred plutonium, in order to get relatively pure Pu-239. You want the produced Pu-239 not to be exposed too long to thermal neutrons, in order to avoid capture, and production of Pu-240 and higher.
So you need continuous loading and unloading, or short cycles, and the amount of Pu in the uranium is pretty low.
In a fast spectrum, you will produce Pu-239. You will also fission some, but you will have a very low capture Pu-239 (n,gamma) Pu-240. So you can irradiate your uranium for a long time, and get out a higher amount of rather pure Pu-239.
I once did the calculation, and you get out a much higher percentage of Pu-239 with fast neutrons (although indeed, you also have fissioned part of it) than with thermal ones if you wait long enough. True, this was with a fission spectrum around 1 MeV and not with a fusion spectrum around 14 MeV...
vanesh,
Go to the Nuclear Data Center at Brookhaven National Laboratory and plot the capture and fission
cross-sections of U-238 as a function of energy. At around 1 MeV; the neutron capture reaction - which
is the one that produces Plutonium for you; starts a precipitous DROP. At about the same place;
the fission cross-section of U-238 starts to precipitously rise.
So at about 1 MeV; your production of Plutonium is falling off, and fissioning of U-238 is going up.
At thermonuclear fusion neutron energy of 14.1 MeV there's about 3 orders of magnitude difference in
the cross-sections. That is for every 1 Plutonium yielding capture reaction; you will have 1000 U-238
destroying fission reactions.
Physicist
For convenience - what Morbius is talking about, U-238 fission vs. neutron capture:
And vanesch, Pu-239 + n --> Pu-240:
Both graphs made with the free online NNDC tools:
http://www.nndc.bnl.gov/sigma/
signerror,
Thank you for posting those graphs.
From the upper graph, you can see that at fusion neutron energies, the fission cross-section is
about 1000 times the capture cross-section. So you are going to get more fissions and less
Plutonium production.
The lower graph shows how the capture cross section that gives you Pu-240 is dropping and at
fusion neutron energies is 1000 times less than the fission cross-section. So you are 1000 times
more likely to fission the Plutonium than to capture the neutron and make Pu-240.
So things "flip around" at about 1 MeV.
Physicist
Morbius said:
signerror,
Yes, as I said, I did the calculation at 1 MeV, not at 14 MeV.
You can find the plots here (sorry that some stuff is in dutch - guess it is clear), I made them using exactly the cross sections that have been displayed (I can post the Scilab code that generates them).
50% of all the EU money going into energy research is scheduled go to hot fusion (ITER funding included)---the other 50% to all other types of energy research combined.
I am geologist; I'd love to spend billions of dollars to install geothermal energy in every single family residence with over a 1/2 acre of land. This would provide thousands of geologists with good, high-paying jobs.
If I were a chemist, I'd love to spend billions of dollars on better batteries, more fuel efficient cars, better insulation, better semiconductors, the realization of high temperature superconductivity, and new energy technologies. This would provide thousands of chemists with good, high paying jobs.
If I were a biologist, I'd love to spend billions of dollars studying cellulose bio fuels, hyrogen-producing algae, ways to harness the promise of unlimited phytoplankton development in the ocean "deserts" where the absence on nutrients makes a food chain impossible. By pumping bottom waters to the surface, it would be possible to grow millions of tons of food for cattle and humans every year by genetically altering phytoplankton to grow faster and produce more proteins. Another possiblility: bio-transmutation of radioactive elements. These projects collectively would provide thousands of biologists with good, high-paying jobs
If I were an atmospheric scientists, I'd love to build windmills everywhere tied to hydogen production, not electricity. This would provide thousands of good, high-paying jobs to atmospheric scientists.
Collectively, they could provide us with all the energy we need FOREVER. And you still maintain we should spend billions of dollars on this pork project for physicists with absolutely no guarantee of success? The people who wanted hot fusion were mostly our wonderful leaders during the cold war so they could tell the Soviet Union, "We put a man on the moon and brought him safely home again; now we are going to conquer the sun". Hot fusion is a Cold War relic that should be shut down immediately. It is a boondoggle, pork for physicists and an albatross around the neck of our goal of energy independence.
The only other people who wanted the hot fusion program are the physicists at the Department Of Energy who wanted to finance their buddies at MIT.
theCandyman said:
Part of the Clinton adminstration's promises were to cut back funding for nuclear related programs. IFR got cut.
sloughter,
100% WRONG again. The National Academy of Science has calculated that renewables
can give us about 15-20% of current electric power demand - AT MOST! Why not
calculate how much energy you can get if you can use the deuterium in the waters of the
world's oceans for fuel. The reason thermonuclear fusion gets so much money is that it
has the potential to DWARF all the sources you cite.
That's a pretty ill-considered statement from a supposed scientist. It is research. When do we
require a guarantee from the scientists before we embark on a research path? True - it is
"high risk" research - in that when it was started it was known that it would be a long task - but
the high payoff makes it worth it. That's the type of research that the government typically funds.
Something that is going to payoff in a year or two is something that industry is willing to fund.
What is your "hang-up" about MIT anyway? What did they do; reject your admission application?
However, again you demonstrate your profound ignorance of the US fusion program. The work
at MIT is actually "small potatoes" compared to other efforts. MIT did NOT have the largest fusion
energy program. The largest magnetic fusion energy program BY FAR was not at MIT but at
PRINCETON:
http://www.pppl.gov/
The Princeton operation DWARFS the MIT operation. Additionally, universities were not the only
players in the magnetic fusion arena - General Atomics is another big magnetic fusion research lab;
again MUCH, MUCH bigger than MIT:
http://fusion.gat.com/global/Home
Another big magnetic fusion program was hosted at Lawrence Livermore National Laboratory:
https://publicaffairs.llnl.gov/WYOP/Fusion_Energy.html
https://www.llnl.gov/str/January01/pdfs/01_01.3.pdf
Lawrence Livermore's other fusion effort in Inertial Confinement or "Laser" Fusion is about to
pay off. A couple weeks ago LLNL dedicated the NIF - the National Ignition Facility. Under
our present understanding of fusion processes - the NIF will have the ability to achieve "ignition";
that is to get more energy out of a burning plasma than you put into it. So why would anyone
shutdown the research effort just when it is about to pay off?
The research in thermonuclear fusion has nothing to do with the Cold War. The motivation for
fusion energy has always been to harness a new energy source rather than as a PR campaign
against the Soviet Union.
The NASA program was more the PR program - but even if the motivation was as a contest
against the Soviet Union; the NASA space program has been great for research. We wouldn't
have the computer power we have today if it were not for advances in scaling down a computer
so that it could go on-board a spacecraft . So who cares what the motivation was - the Space
Program was very good for the USA's science program.
Physicist
vanesh,
Yes - well as you can see 1 MeV is where everything "turns around".
Physicist
The major problem with Inertial Confinement Fusion is that physicists think it is a physics problem. It is an engineering problem. Getting fusion is 1% of the job. 99% is the supporting engineering. I don't see anyone defending the farcical cartoon on Charlie Gibson showing an ICF reactor firing every second (Do you really think that it is possible to go from 100,000,000 degrees to -260 degrees in under one second?). Do you really think that you can isolate lasers from the explosive force of a 100 pound stick of dynamite going off a few feet away? Do you really think that one detonation means anything when you are going to have to get a detonation every second? Do you really think hitting a stationary target has any relevance to hitting a moving target? Hitting a static target is comparable to hitting a missile on a launch pad as opposed to hitting it in flight. Do you really think that Star Wars in a bottle is feasible?
This is just a partial list of all the engineering problems faced by ICF engineers.
sloughter,
Funny you should mention "Stars Wars'. I remember when so many of the self-proclaimed
"experts" said that Livermore's X-ray laser would never work. Well, it turns out they were WRONG!
We now even have table-top X-ray lasers:
https://www.llnl.gov/str/Dunn.html
Actually, the plans are to have the reactor fire about 10X per second. The reactor doesn't have
to go from 100M degrees to -250 degrees. Where did you get that idea? The only thing that needs
to be at those temperatures is the fusion capsules - NOT the entire reactor - and you got the
temporal gradient wrong. It goes from -250 degrees to 100M degrees - and that certainly IS
possible given the energy released. Why do you "think" the capsule can't do that?
As I told you last time - and you've evidently failed to absorb the information - the lasers are NOT
a few feet away from the target. They are hundreds of feet away. You do know that laser light
can propagate a fair distance - you don't need the laser amplifiers right next to the target.
If what you are saying was true - we'd destroy NIF the first time we fire it. That's not going to
happen.
Why don't you read up on ICF - because you really don't know what you are talking about.
It sounds like the clap-trap that comes off the anti-nuke websites.
Physicist
sloughter,
Why not? You just need a big volume to contain the energy - like the target chamber at NIF.
LLNL does that type of testing with normal chemical high explosives all the time at HEAF -
High Explosives Applications Facility.
High Explosives are test-fired in big tanks - and some of the diagnostics are lasers. So there's
no problem isolating an explosive of modest size [ not a huge truck bomb ] from the environs.
https://wci.llnl.gov/fac/heaf/Media/jpg/1Ktank001.jpg
It's not like you don't know what the yield of the capsule is - and you design the facility to
tolerate it.
Physicist
sloughter,
Except you know EXACTLY the trajectory of the capsules. One design has the capsules attached to
a wire guide that traverses the target chamber. It's like a miniature version of a cable car - like they
have at ski slopes. The capsule isn't in free flight like a missile - it has to be where the cable constrains
it to be - so it has to be along the cable. Since you are also pulling the cable - you know how far along
the cable the capsule is - and that gives you the location of the capsule.
Don't you know where a cable car is at a ski slope if someone has told you how much cable has been
played out since the car left the terminal building?
Physicist
Morbius said:
sloughter,
The cable must also be obliterated with the shot. Then what? Cable per shot? Just curious.
sloughter said:
Last thing I read was that MIT has gotten $15 billion for their hot fusion program and a total of $20 billion has been spent on the hot fusion program in this country so far.
sloughter,
WAY WAY WAY WRONG!
MIT's effort in fusion may be on the order of a few million NOT a few billion. I think you've confused
millions and billions. BY FAR - the major effort of the magnetic fusion research has been at
Princeton. The Princeton Large Torus [ PLT ] and the Tokamak Fusion Test Reactor [ TFTR ] have
both been at Princeton. The Dept. of Energy established one of its national laboratories at
Princeton - the Princeton Plasma Physics Lab [ PPPL ]:
There's no national lab scale effort at MIT. MIT runs a small tokamak called "Alcator". The MIT
effort is on the order of a few million. Again, I think you didn't keep "millions" and "billions" straight
in your reading.
The budget for a big national lab like Lawrence Livermore is 1 Billion / year. Lawrence Livermore
get that $15 Billion in a 15 YEARS! That's to run the WHOLE LAB!
The fusion effort at MIT is one small tokamak and may have consumed a few million dollars.
Again, I would posit you've been sloppy in your reading and confused millions with billions.
Physicist
