Integral involving exponential
  • Context: Undergrad
  • Thread starter Thread starter stevendaryl
    Exponential Integral
9 replies · 2K views
Staff Emeritus
Homework Helper
Insights Author
Just a quick question:
Does anybody know if there is a closed-form solution to this rather simple-looking definite integral?
##F(\lambda) = \int_0^{\infty} \dfrac{e^{-x}}{1 + \lambda x} dx##
If ##\lambda > 0##, it definitely converges. It has a limit of 1 as ##\lambda \rightarrow 0##. But it doesn't seem to be analytic in ##\lambda##, since if you try to do a power series in ##\lambda##, you get a nonconvergent sequence:
##F(\lambda) = \sum_{j=0}^\infty (-1)^j \lambda^j (j!)##
[tex]\frac{1}{1+\lambda x}=\sum_{j=0}^\infty (-\lambda x )^j[/tex]
only if ##|\lambda x| < 1##?
only if ##|\lambda x| < 1## ?
Yes, the summation doesn't converge if ##|\lambda x| > 1##. It's even worse if you put the factorials in:
##\sum_{j=0}^\infty (-\lambda)^j j!##
doesn't converge for any nonzero value of ##\lambda##.
It looks like the Gamma function. See 1.1 / 1.8 / 2.3 in https://de.wikibooks.org/wiki/Formelsammlung_Mathematik:_Bestimmte_Integrale:_Form_R(x,exp)
or the integration trick used here:
https://www.physicsforums.com/threads/micromass-big-integral-challenge.867904/page-2#post-5451293
If ##\lambda <0## then the integral is not defined, so you generically should not expect to get a power series around 0 that works.
Setting ##t \equiv 1/\lambda + x##, you get
F(\lambda) = \frac{e^{1/\lambda}}{\lambda} \int_{1/\lambda}^{\infty} \frac{e^{-t}}{t} dt = \frac{e^{1/\lambda}}{\lambda} \Gamma(0, 1/\lambda)
where ##\Gamma(s, x)## is the incomplete gamma function.
  • Wow
If you don't mind sharing, how did you notice this? Was it because you saw a similar integral, or was it a guess/intuition?
I started from the solution Mathematica gave to the integral and then played around until I could understand how to get such a solution.
Using "special functions" is a way of cheating, since all the theory of integrals in terms of them is already embedded either in a book like Abramowitz-Stegun/Gradshteyn-Ryzhik, or in a computer software to which G-S has already been fed + it was taught various substitution techniques.
Therefore, when you see the integral and in the absence of a computer software you can feed the problem to,
you can try to devise certain substitutions to bring it to a form already present in G-S.
Here is how it's done.
https://en.wikipedia.org/wiki/Exponential_integral
In order to bring it to the https://en.wikipedia.org/wiki/Exponential_integral, you need to first substitute
$$ 1 + \lambda x = t$$
Then the integral is just a numerical factor times ##\text{Ei}\left(-\frac{1}{\lambda}\right)##
I need to get more comfortable using those books, I remember my physics teacher in high school showing me that one with the red cover. But thanks for the insight!
