Integral of Absolute Value Function
The problem involves evaluating the integral of the absolute value function \(\int^{8}_{0}\left|x^{2} - 6x + 3\right|dx\), which is situated within the context of a single variable AP Calculus AB class. The original poster attempts to solve it using a substitution method while grappling with the implications of the absolute value in the integral.
  • Participants discuss the importance of identifying where the expression inside the absolute value is positive or negative. Some suggest finding the zeros of the quadratic function to determine the intervals of positivity and negativity. Others express uncertainty about the implications of negative intervals and seek clarification on how to handle these in the context of the integral.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the need to analyze the quadratic function's behavior across the specified interval, but there is no explicit consensus on the approach to take.
Participants note that there may be gaps in foundational knowledge regarding quadratic equations, which could affect their understanding of the problem. There is also mention of missed class content that may be relevant to the current discussion.
weiseguy
This is for a single variable AP Calculus AB class in which we are solving using substitution method.
2. The attempt at a solution
I attempted it by just ignoring the abs value bars thinking that anything I am finding out "how much" of will be positive, and the negatives won't count. Solving with this in mind:
I came to the answer of 128/3
Please help as you can
when solving abs equations, first find the zeros and find out which part is negative, then do the integral for the individual part, when you get negative just take the abs value then add all the parts in the interval up.
So (I haven't checked), if the interval 0 to 3 is negative and 3 to 8 is positive. I would say the answer is the negative interval plus the positive one?
I need a little further explanation I think. We just started this in class and I had to miss half of the lecture.
What do you mean "negative interval"?
You know how the integral is the area above the curve minus the area below? Graph it and see.
Why would "negatives" not count? You can't ignore the abs value- you need to determine where x2 - 6x+ 3 is positive and where it is negative. Start by determining where x2- 6x+ 3= 0.
You should have learned to solve quadratic equations long before a calculus class! I doubt that the part you missed was devoted to solving x2- 6x+ 3= 0! No, x= 3 is NOT a solution.
I believe I stated "if for example the interval 0 to 3 was negative" not that it WAS indeed negative. It was 11pm and I didn't feel like doing any work at the moment. Basically though, I split the two up and add them together to find the total. It's like a displacement problem?
