Integral of root(-x^2+10x-16)dx
  • Thread starter Thread starter jason_r
    Integral
14 replies · 3K views
jason_r
integral of root(-x^2+10x-16)dx
i can factor the thing inside the root to (x-8)(x-2) if i pull out the negative sign
no idea what to do after that
which root the square root? that factorization won't help you get anywhere good, but if you complete the square I think you'll find yourself with something you can work with.
Try rewriting the quadratic expression under the square root symbol in vertex form
sqrt[a]*sqrt[(x-h)^2 + k^2)] , as follows:
sqrt[-1]*sqrt[(x-5)^2 - 9], then let u = x - 5, and use the formula from a table of integrals for an integral of the form
sqrt[u^2 - a^2], for a > 0, and then make the appropriate back substitutions.
Note: the sqrt[-1] is just a constant, albeit a complex constant, so it can be pulled out side of the integral. The integral will turn out to be real-valued none-the-less.
I hope this helps.
no need or use to pull -1 outside the squareroot
complete the square make the substitution, then integrate
hmm I am having trouble integrating sqrt(u^2 - 9)
would i need to use integration by parts?
That makes sense, then it would just be an integral of the form
sqrt[a^2 - u^2], for a > 0.
Try the triq substitution of
u = 3*sin(v) for
sqrt[9 - u^2], here we just didn't factor out the -1.
im lost...this is as far as i get
-(integral) sqrt(u^2 - 9)
i don't understand how i can use a trig identity to simplify that
Hmm, not sure how well trig sub works here
have a look at the derivative of arcsin...
The trig substitution x= 3 sin t will give the same thing as the arcsine integral.
