What is the integral of x²e^-x²?
  • Thread starter arsmath
  • Tags
    Integral
In summary: Oh sorry, my mistake.now i guess he can express the last part in terms of the error function,If you've proved\int_0^\infty dx~e^{-x^2} = \sqrt{\pi}you should be able to extend that result to the more arbitrary case\int_{-\infty}^\infty dx~e^{-\alpha x^2} = \sqrt{\frac{\pi}{\alpha}}by substitution.Now, the Liebniz rule for integrals says that (in the case of constant limits)\frac{d}{d\alpha}\int_a^b dx f(x,\alpha) = \int_a^b dx\frac{\partial f(x,\alpha
arsmath
I am working on an integral I am finding tricky, and I think I'm missing something.
I need to integrate on the interval 0 to infinity, x²e^-x².
We have proved that on the interval of -∞ to ∞, e^-x²=√∏ so from o to ∞, it equals √∏/2. I can use this in my proof, but I don't see how. When I try integrating by parts I have trouble getting a finite answer. I would love some help,
The functions symmetric so I don't see your issue. Out of curiosity how did you prove the first integral as if I recall correctly the improper integral is done using residues. The proper integral can also be solved if you don't mind solutions in terms of error functions.
Well, then show what you did!
its the euler poisson gaus integral and evaluate it as a double integral, to be honest the proof is a bit over my head.
I've heard of that method, I believe it uses polar coordinates. That said the better way to solve it is via residues:
http://en.wikipedia.org/wiki/Methods_of_contour_integration
ok here goes:
from 0-∞∫ x²e^-x²dx
u= x² dv = e^-x²dx
du=2xdx v=∫e^-x²dx
(x²∫e^-x²dx) – (2∫xdx)(∫e^-x²dx)
since I have that from 0-∞∫ e^-x²dx = √∏/2
I have x²(√∏/2) -√∏ which when evaluated on the interval 0-∞ goes to ∞. . .
This makes me think I’ve done it incorrectly
cant one just go like this
integ(x^2e^-x^2)dx=integ(x*x*e^-x^2)dx, and then take u=x, du=dx, and v=integ(x*e^-x^2)dx, this last one can be done using the sub -x^2=t=> -2xdx=dt, xdx=-dt/2.
THis is easier i guess!
I think that may help.
that is my all time favorite xkcd comic.
arsmath said:
ok here goes:
from 0-∞∫ x²e^-x²dx
u= x² dv = e^-x²dx
du=2xdx v=∫e^-x²dx
I'm not sure what you have done is valid as this:
(2∫xdx)(∫e^-x²dx)
seems illegal.
(2∫xdx)(∫e^-x²dx)
seems illegal.
i think you're right, and I appreciate the feedback. . .so I'll try to hit it from another angle. thanks
Did you try to work through post #7?
The first substitution you did does not change the integral. You made a mistake.
Why not write out how you solved it for the limits from -oo to oo and we can see if we can extend the method. If you're interested I can show you how to solve the equation for the proper integral but I don't think that is what the teacher is looking for as you haven't learned about the error function yet.
Yes you are right that, indeed, it does not change the integral at all, it ends up with
integ e^(-x^2)dx. Besides this what mistake are you talking about?
no the integrand remains unchanged. That is you now have
u^2e^(-u^2)du
and I wasn't talking about any other mistake.
u^2e^(-u^2)du
now v=-1/2e^(-x^2), now going back to integ by parts we have
-1/2 xe^-x^2 +1/2 integ (e^-x^2) dx
i do not see how you will end up with the same integrand.!
If you've proved
[tex]\int_0^\infty dx~e^{-x^2} = \sqrt{\pi}[/tex]
[tex]\int_{-\infty}^\infty dx~e^{-\alpha x^2} = \sqrt{\frac{\pi}{\alpha}}[/tex]
by substitution.
[tex]\frac{d}{d\alpha}\int_a^b dx f(x,\alpha) = \int_a^b dx\frac{\partial f(x,\alpha)}{\partial \alpha}[/tex]
With this in mind, can you figure out how to evaluate your integral?
(I don't know if you're allowed to do it this way if this is homework, but it's a clever trick...)
1. What is the formula for the integral of x²e^-x²?
The formula for the integral of x²e^-x² is ∫x²e^-x² dx = -1/2 e^-x² + C.
2. How do you solve the integral of x²e^-x²?
To solve the integral of x²e^-x², you can use the substitution method or integration by parts. Using substitution, let u = -x², du = -2x dx. Then the integral becomes ∫x²e^-x² dx = ∫e^u * (-1/2 du) = -1/2 e^u + C = -1/2 e^-x² + C.
3. What is the purpose of the integral of x²e^-x²?
The integral of x²e^-x² can be used to find the area under the curve of the function x²e^-x². It is also used in various fields of science, such as physics and engineering, to solve problems involving rates of change.
4. Can the integral of x²e^-x² be evaluated using a calculator?
Yes, the integral of x²e^-x² can be evaluated using a calculator by inputting the function and the limits of integration. However, it is important to note that the result may not always be accurate due to rounding errors.
5. What is the significance of the constant C in the solution for the integral of x²e^-x²?
The constant C represents the constant of integration and is added to the solution to account for all possible solutions of the integral. This is because the derivative of a constant is always 0, so adding a constant to the solution will not affect its derivative.
  • Calculus
  • Calculus
  • Calculus
  • Calculus
