Integral with radical denominator.
  • Thread starter Thread starter Idoubt
    Integral Radical
8 replies · 5K views
Idoubt
Need to do this integral as part of a problem
[itex]\int[/itex] [itex]\frac{xdx}{\sqrt{x^2+a^2-\sqrt{2}ax}}[/itex]
I can't think of any substitution that would work, or any way to factorize.
I think this is a standard integral, but can't remember everyone so I just want to learn to solve it.
Your first step would be completing the square in the denominator. What does the integral look like after you do that?
I would try writing [itex]x^2+a^2-\sqrt 2 ax = x^2- \sqrt 2 ax+ \frac{a^2} 2 +(a^2-\frac {a^2} 2)<br /> =(x-\frac a {\sqrt2})^2+\frac{a^2} 2[/itex] and see if that leads anywhere.
[Edit] I see Dick types faster than I do...
[Edit] Fixed a typo and its ramifications.
LCKurtz said:
I would try writing [itex]x^2+a^2-\sqrt 2 ax = x^2-2\sqrt a + a +(a^2-a)<br /> =(x-\sqrt a)^2)+(a^2-a)[/itex] and see if that leads anywhere.
No, we type about the same. I just say less.
It appears that you have changed [itex]\sqrt{2}ax[/itex] into [itex]2\sqrt{a}[/itex], but apparently meant [itex]2(\sqrt{a})x\,.[/itex]
Yes, thanks. I edited it (about 3 times :frown:) to correct it.
You are letting the radicals and the denominator distract you. If you re-write as
Int (mess)^(-1/2) * xdx, you should see a u-substitution and integration by parts.
ok when I complete the squares and do it, i get the answer as
[itex]\sqrt{x^2+a^2+\sqrt{2}ax}[/itex] + [itex]\frac{a}{\sqrt{2}}[/itex] ln |[itex]\sqrt{a^2+x^2}[/itex] + x |
Which is the right answer i think. thanks a lot for the help :)
If i do the U substitution, I don't see how i can write x in terms of u
