Integrate f(x) = (x^3 + 3x + 12) / (x(x+2)^2)
  • Thread starter Thread starter Hevonen
    Integrate
To integrate the function f(x) = (x^3 + 3x + 12) / (x(x+2)^2), it is essential to rewrite the polynomial using partial fractions. The correct approach involves expressing f(x) as a sum of fractions: f(x) = A/x + B/(x+2) + C/(x+2)^2, where A, B, and C are constants to be determined. Long division should be performed first since the degree of the numerator exceeds that of the denominator. After dividing, the resulting expression can be decomposed into partial fractions for easier integration. This method ensures the numerator is of lower degree than the denominator, which is necessary for partial fraction decomposition to work correctly.
Hevonen
I know that i should somehow rewrite the polynomial but I do not know how. Please, help me.
Hmm, I don't know if this is correct or not, but have you tried long division?
You should rewrite your polynomial as sum of partial fractions, hope you know how to do that. You write
f(x) = \frac{x^3 + 3x + 12} { x(x+2)^2} = \frac{A}{x}+\frac{B}{x+2}+\frac{C}{(x+2)^2}
Where A,B,C are constants. Then you have to solve a system of three equations for A,B,C. Else you look in math book or wikipedia under partial fractions.
Thanks! It is about partial fractions.
I would strongly recommend that you multiply out the denominator and divide first. "Partial fractions" only works correctly when the numerator is of lower degree than the denominator.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
