Integrating a delta function with a spherical volume integral
The discussion revolves around integrating a three-dimensional delta function, specifically $$\int_V \delta^3(\vec r)~ d\tau$$, over a spherical volume as part of a problem in an E&M class. Participants are exploring the implications of using spherical coordinates in this context and the nature of the delta function as a distribution rather than a conventional function.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are attempting to understand why the integral of the delta function appears to yield zero when expressed in spherical coordinates, despite the expectation that it should equal one. There are questions regarding the treatment of the delta function in different coordinate systems and the implications of its definition as a distribution.
Some participants have offered insights into the nature of the delta function and its representation, suggesting that the misunderstanding may stem from the differences in integration approaches between Cartesian and spherical coordinates. Others are seeking clarification on specific mathematical explanations and how they relate to the definitions provided in their textbooks.
There is a noted confusion regarding the application of the delta function in three dimensions versus one dimension, particularly in relation to the volume element used in the integral. Participants are also grappling with the implications of the delta function's properties and how they affect the outcome of the integral.
counterpoint1
Integrate $$\int_V \delta^3(\vec r)~ d\tau$$ over all of space by using V as a sphere of radius r centered at the origin, by having r go to infinity.
This integral actually came up in a homework problem for my E&M class and I'm confused about how to handle it. I understand that the delta function will make the volume integral come out to one, but when I express that integral as a triple integral over spherical coordinates, $$\int_0^{2\pi}\int_0^\pi\int_0^\infty \delta^3(\vec r)~ r^2 sin(\theta)~ dr~ d\theta~ d\phi$$ The integrating factor apparently makes the integral go to zero, since ##\delta^3(\vec r)~r^2=0##.
In my textbook, the author uses the delta function to say that ##\delta^3(\vec r)~r=0## and I can understand that since ##\delta^3(\vec r)~r = \delta(x)\delta(y)\delta(z)~\sqrt{x^2+y^2+z^2} = 0##. But then, given that, I'm at a loss as to what went wrong when I set up the integral.
The delta function is not a function. It's a distribution. If you want to do this rigorously then the actual definition of
##\delta^3(\vec r)## is the limit of real live functions that are not 0 when r is not zero. To say it's infinity at r=0 and zero otherwise is a gross simplification. I assume that's what you are basing your argument on.
So ... the volume integral doesn't go to zero because the limiting process is different in spherical coordinates as opposed to Cartesian, and it matters whether I'm using a volume integral like ##\iiint dx~dy~dz## as opposed to ##\iiint dr~d\theta~d\phi## ?
EDIT: That is, I understand that the delta "function" only has meaning inside an integral, and I'm vaguely aware that a distribution is defined as a limit of functions in an integral, so the reason why the volume integral I used doesn't just go to zero is because of the specifics of integrating in spherical coordinates? I'm not too familiar with that math, honestly.
No, the limiting process is the same in cartesian and spherical. You can define a representation of the delta function as, for example, a sequence of functions that have value 0 outside of r=1/n, but inside have value n^3*3/(4*pi). The total integral of each representative is 1 and they vanish outside of radius 1/n.. And yes, if you integrate that against a function and take the limit as n->infinity, that's the delta function. The volume element doesn't have much to do with it. You could also use cubes. Notice the the functions in the sequence are not 0 when r is not zero.
I have the exact same problem: from the definition ##\int f(x) \delta(x) dx = f(0)##, one'd think ##\int \delta^3(\vec r)~ r^2 dr d\Omega = 0##, but this is obviously wrong.
However, I struggle with understanding Dick's math-talk explanation, so is there some way to explain it based on what's written in Griffiths text on electromagnetism?
##\delta(x)## and ##\delta^3(\vec{r})## are different objects, so while you have ##x\delta(x) = 0##, it doesn't necessarily follow that ##r\delta^3(\vec{r}) = 0## (as opposed to ##r\delta(r)=0##). To write ##x\delta(x) = 0## is relatively safe because the expression will appear as part of a one-dimensional integral. You tack on a ##dx## and integrate. On the other hand, ##\delta^3(\vec{r})## only makes sense in a three-dimensional integral, so there's possible confusion arising from the volume element in different coordinate systems. You need to think carefully about what the expression ##r\delta^3(\vec{r})## means.
One of the properties of the three-dimensional delta function is
$$\int f(\vec{r}'-\vec{r})\delta^3(\vec{r}')\,d^3\vec{r}' = f(\vec{r}).$$ If you're avoiding distributions, this would, in fact, be one of the defining properties of the three-dimensional delta function. The factors that can cause that integral to vanish come from ##f##, not the volume element. So when the author says ##r \delta^3(\vec{r}) = 0##, he means that
$$\int r\delta^3(\vec{r})\,d^3\vec{r} = \iiint r\delta^3(\vec{r})\,r^2\sin\theta\,dr\,d\theta\,d\phi=0.$$ The mistake in saying that
$$\iiint \delta^3(\vec{r})\,r^2\sin\theta\,dr\,d\theta\,d\phi = \iiint [r\delta^3(\vec{r})]\,r\sin\theta\,dr\,d\theta\,d\phi = 0$$ is that the second integral is no longer an integral of the form ##\int [f(\vec{r})\delta^3(\vec{r})]\,d^3\vec{r}## so the meaning of the delta function is no longer clear. Specifically, in the context of that integral, you can't say that ##r\delta^3(\vec{r}) = 0## and deduce that the integral vanishes.
  • · Replies 19 ·
